Help for an old blind man?
Discussion in 'Tele-Technical' started by GERARD9415, Jun 21, 2021.
  1. GERARD9415
    GERARD9415 Tele-Meister
    STATEN ISLAND, NY
    ok, I am legally blind and have arthritis in my hands, so I bought extra light guitar strings. The problem is restringing my fender telecaster. I finally got the strings thru the plate but now I am having trouble getting the 1st high E string thru the tuning peg. Any suggestions that will help.
    _MementoMori_ likes this.
  2. _MementoMori_
    _MementoMori_ Tele-Afflicted
    Nice try, Big Brother.
    Sorry you're having troubles. Are your tuners vintage style, or modern style with the tiny hole in the post that you have to thread the string through?
    I think you would love vintage style tuners if you don't have them. They're much easier to string.
  3. GERARD9415
    STATEN ISLAND, NY
    Modern style with hole.
  4. _MementoMori_
    The only tip I can give is to turn your post so that the opening is lined up with the fretboard before stringing. Then it's just a matter of running the string in a straight line into the post. But if I were you I'd strongly consider vintage style tuners. They're amazing anyway and once you've tried them you'll never want anything else.
  5. Mike_LA
    Mike_LA Tele-Afflicted
    Just past 11 on the Dial
    You might upgrade to locking tuners.
    Push the string thru the hole in the post, tighten the locking screw on the back of the tuner, tune up, good to go.
    Best of luck
    teleplayr and JL_LI like this.
  6. Harbinger77
    Harbinger77 Tele-Meister
    Boston
    I’m blind too.
    Locking tuners make string changes easier but they don’t solve all the issues I have.
    sometimes I thread a thicker string through with it so the blockage doesn’t make the thin string bend.
  7. Peegoo
    Peegoo Poster Extraordinaire
    Between the Raindrops
    Have a guitar tech (or a pal who knows how to use tools) drill out the holes in the posts a little larger to make it easier to poke the strings through. Also ask them to use abrasive cord to polish the sharp edges of the drilled holes to make things smooth and prevent cutting the strings.
  8. GERARD9415
    STATEN ISLAND, NY
    Thanks for all the suggestion, I will do my best with them.
  9. E5RSY
    E5RSY Doctor of Teleocity
    Georgetown, TX
    I think you would benefit immensely from having split-shaft vintage type tuners installed and learning to use them as they were intended.
  10. Tommy Biggs
    Tommy Biggs Friend of Leo's
    Northern NJ
    Could you slip a cocktail straw over the string end and then run that through the tuner?
    I’m just spitballing here, trying to help out.
    Might require getting a friend to go to a bar though- although a wd40 straw would work too.
    Harbinger77 and Greggorios like this.
  11. GeneB
    GeneB Tele-Meister Silver Supporter
    Tampa, FL
    Good idea ... I use one through the ferrules of my Carvin to get the strings through them more easily. It should work for tuners too.
    Tommy Biggs and Greggorios like this.
  12. Harbinger77
    Boston
    I am blind, too. I do this with the high e with my fender locking tuners.
    Locking tuners are also worth the investment.
    Tommy Biggs likes this.
