Help Finding Parts for Treble Bleed
Discussion in 'Shock Brother's DIY Amps' started by OldPup, Apr 7, 2020.
  1. OldPup
    OldPup Tele-Meister
    Charlotte, NC
    I would love to install some treble bleed circuits in my HH style guitars. I have decided to wire them the way Fender does on the AmPro series, since I have a 2017 AmPro Tele and I love the way it sounds. I would like to track down a 1200pf cap, 0.022uf cap, 20k and 150k ohm resistors. I can find 0.001uf caps. This value does not line up exactly with 1200pf nominally, but is close. Are the two in fact interchangeable? Where does everyone go to find these components?
  2. dunehunter
    dunehunter Tele-Holic Double Platinum Supporter
    Larkspur, CO
    Mouser is a good source for all things electronic. I tend to go to them for highly specialized parts. Otherwise, I find almost everything at Antique Electronic Supply.
    The difference between 1200 pF and 1000 pF is within 20%. Close enough, I think. Don't spend a lot of money on this--Fender buys stuff in bulk and gets huge discounts. Just get close enough and I think you'll be happy with the result.
    I did one for my Tele a few months back and am totally pleased--and didn't spend an arm and a leg. I'll get you the specs of mine as soon as I go downstairs and open up my guitars control cavity...
  3. Si G X
    Si G X Tele-Holic
    England
    You should be able to buy the caps anywhere, look for 1.2nF (or 0.0012uF, all the same thing) a very common value.
    agreed, no need to spend a lot of money, they should cost pennies. I buy all my components direct from China but you should be able to find ebay resellers that will sell you a few at very minimal cost. I'm looking at a US seller now that's selling 100x 1.2n caps for $2.69 ... not that you'll want 100 of them. :D
  4. OldPup
    OldPup Tele-Meister
    Charlotte, NC
    Mouser... I knew that would come up... That website is a little arcane for me - the bane of my guitar DIY existence. I love to solder and put stuff together, but I am not up on all the variables Mouser asks for as I try (and fail) to select components. I will try again and come back with questions as I get stymied. Maybe I'll learn something.
    Kevin Wolfe likes this.
  5. dunehunter
    Larkspur, CO
    Here is my treble bleed, nothing special--just parts I had on hand:
    That's a 1/2 W, 150K Ohm resistor across a 1000pF Cap. The 600V is overkill, but it's what I had on hand. At any rate, seems to work great. Parts all came from Antique Electronic Supply
    6stringcowboy likes this.
  6. OldPup
    OldPup Tele-Meister
    Charlotte, NC
    Sweet! Thanks for posting the pic. Does the legs need to be in the shrink wrap? If not, I guess I will need to buy a heat gun... which I'd rather not do.
  7. Lowerleftcoast
    Lowerleftcoast Tele-Holic
    california
    You may want to rethink this. One size may not fit all. The humbuckers generally use different value pots and different value treble bleed circuits.
    I would have a look at the les paul type sites to see what values of treble bleed they prefer for the HH style. YMMV.
    OldPup likes this.
  8. schmee
    Yeah, try AES. I wont shop Mouser unless there is no alternative. They try hard to make it difficult.
    Kevin Wolfe and 6stringcowboy like this.
  9. OldPup
    OldPup Tele-Meister
    Charlotte, NC
    I'm relieved to learn it's not only me that struggles with that site! I will try AES. Thank you.
  10. wabashslim
    wabashslim Tele-Afflicted
    Sonorous Desert
    Right, you'll want an assortment of values because different pickups will want different values for best results. Depends on their DC resistance, inductance, the pot values, etc. There's no formula, you just have to experiment to find what you like best.
  11. Norris Vulcan
    Norris Vulcan Tele-Holic
    Somerset, UK
    You know you can just clip different value caps on with croc clips ?
    Try a few out through your amp - you may be surprised what values sound best ;)
    OldPup likes this.
  12. dunehunter
    Larkspur, CO
    Don't need a heat gun if you have access to your wife's/girlfriends blowdryer. Works fine. I just use the heat shrink to keep other parts from grounding it out when you mash everything back into the cavity.
    Mash is perhaps not the word I'm looking for but you get my drift...;)
    OldPup likes this.
  13. archetype
    archetype Fiend of Leo's
    Williamsville NY
    IMO Mouser does a good job of letting the user filter to the part that's needed. You have to know exactly what you need. What you're working with is a user interface that builds queries against a database the size of Switzerland. There isn't a more user-friendly way to do this in that kind of scale.
    dunehunter likes this.
  14. archetype
    Williamsville NY
    The lazy way is to clip in a capacitor decade box that lets you switch between different values. You enter the lazy genius realm if you clip a resistor decade box in parallel across that.
    jvin248, tubegeek and Norris Vulcan like this.
  15. Peegoo
    Peegoo Friend of Leo's
    jvin248, Kevin Wolfe and PCollen like this.
  16. tele_savales
    tele_savales Tele-Holic
    Brooklyn, Joey!
    Agreed. I got some super tiny ceramic discs from Radio Shack online and its really nice not to have a single orange drop taking up have the control cavity. They sound fine.
  17. beyer160
    beyer160 Friend of Leo's
    On Location
    Whenever I need small quantities of cheap parts, I look on eBay. You can often get what you need for less than the shipping charge from larger retailers.
    tubegeek likes this.
  18. jackal
    jackal Friend of Leo's Gold Supporter
    mojave desert
    Amazon has package deals with caps and resistors in varying values. Those and a simple set of leads with alligator clips will let you find the components that work for you. As for heat shrink, just use a size that fits, no need to shrink it for this purpose. (If you are very careful, you can shrink it with a bic lighter.)
    Steve Holt likes this.
  19. jvin248
    jvin248 Poster Extraordinaire
    Lions & Tigers oh Mi !
  20. archetype
    Williamsville NY
    Yes, the composition of the capacitor has zero effect on tone, and money spent on composition is wasted. But... The caps you mention often have smaller tolerances that put them closer to their nominal values. If you are comparing different values, small tolerances get you closer to comparing apples to apples.
