Help Figuring out what's broken in Fender Vibrolux Custom
Cheap Trills
internet
Try these guys, they have everything for amps. I've ordered from them many times before and also picked up an order there once when I was in Phoenix.
There are several other leading amp supply part vendors on the web, and it may be a good idea to get familiar with them all for when you need misc parts.
Thank you, just ordered a 5 pack from here. Cheers!
Cheap Trills
internet
Anyone know about the "low breaking" vs "high breaking" in fuses and what would work for the main fuse of a guitar amp? I am looking for backup fuses for my tube amps after this experience and I see pretty often rather than being listed as T3A, it'll be listed as T3AL or T3AH.
Wally
There is a short explanation near the beginning of this link.
Askwhy
Utah
The complete and total idiocy of fuse labeling has been a low-level pet peeve of mine for many years.
Wally
The system is necessarily complex as is almost any code system. There are a LOT of fuses with differing specs that need to be applied in a brief format. If the system were idiotic, I am sure that some clever person would have simplified it by now.
I do agree that having more than one code to designate say a slo-blo 2 amp fuse of a certain size is even more confusing, but I have to think that such a situation has more to do with establishment of codes systems in different countries. Ex: MDL 2A and TAL 2A….same fuse….2 amp slo-blo of the same size…1/4” x 1 1/4”.
ETMusic777
Parts Unknown
I have pretty darned good eyes (20/10) and its getting more and more difficult to read the imprint on a modern fuse without a magnifying glass. The older ones seem to have a deeper, easier to read imprint. Or maybe I am just getting old.
Cheap Trills
internet
Is there a store nearby that sells guitars and amps? They may have fuses on hand.
I called around, it's not the "standard" fender fuse, so they didn't have. But I was able to purchase it online at the suggested site from above
Burning Fingers
The worst part is that you can’t test a fuse without making it useless!
Huh ??? a fuse that tests fine with a multimeter is not useless...a correct rating fuse that is put into an amp and does not blow when the amp is turned on is not useless. A blown correct rating fuse is not useless as it indicates a problem in the amp and has protected the amp from possible serious damage. The only useless fuse is one that doesn't blow when it should and I have never met a fuse like that.
corliss1
Gold Supporter
Lansing, MI
I *think* he was saying pushing the fuse to it's breaking (blowing?) point, but it was still an odd phrase for sure. I've never had a reason to test a fuse in such a way. They are labeled for a reason :D
MatchlessMan
Wiltshire UK
Ha, yes I didn’t think that one through! I meant you can’t test a fuse’s rating without blowing it. Of course you can test its continuity - out of circuit, or you risk confusing yourself when current finds another way past a blown fuse.
