Help dating electronics/control plate
Discussion in 'Vintage Tele Discussion Forum (pre-1974)' started by pcasarona, Dec 1, 2017.
  1. pcasarona
    pcasarona Tele-Holic
    Auburn, AL
    Hi all,
    Best guesses on dating this control plate and electronics. Came out of a '71. Could this be original? I have serious doubts regarding the switch!
    Thanks much,
    Paul
  2. Antoon
    Antoon Tele-Afflicted
    Low Lands
    Yeah, switch is an aftermarket Oak switch but the pots and caps seem original to me. What is the pot date and value? I have my doubts about the knobs though
    pcasarona likes this.
  3. BopT
    BopT Tele-Afflicted
    Chicago
    One pot has a 1965 date can't see the other switch is oak replacement. Caps look correct.
  4. pcasarona
    Auburn, AL
    Both pots are dated 49th week of '65. I was a little surprised to find '65 pots. I know that Fender bought a boat load of CTS pots in 66 and that it is not unusual to find '66 pots in late 60's and early 70's guitars, but I didn't know that a '71 could still have '65 pots. What looks funny about the knobs to you?
    Thanks,
    Paul
  5. GGardner
    GGardner Friend of Leo's
    NJ
    My advice for dating electronics: dinner and a movie. No swimming.
    2blue2 and pcasarona like this.
  6. pcasarona
    Auburn, AL
    I found this switch in the case. I assume it is the original, but I also assume there is something wrong with it since it was changed out.
  7. blue metalflake
    blue metalflake Doctor of Teleocity
    ireland
    Knobs look fine
  8. Antoon
    Low Lands
    Yes maybe it is the picture. They have to have a very small dome
  9. ndeli55
    ndeli55 Tele-Afflicted
    oklahoma
    In not sure that relationship will have a future with continuity
  10. Redd Volkaert
    Redd Volkaert Tele-Holic
    Galax, Virginia
    I bet the switch is still good, unless somebody bends parts too much or
    the switch part breaks away from the top, it can be fixed.
    I bet if you check all the u shaped tabs and make sure they are touching the wiper
    when moving the switches positions it should work fine . . . then put it back.
    Sometimes when someone folks around in the cavity too much without care,
    those little tabs get bent away from the wiper . . . worth a try
    Wally and pcasarona like this.
  11. pcasarona
    Auburn, AL
    Thanks, that's what I'm hoping. I will definitely check it out and use it if there is any way possible to make it work. As far as I can tell, the guitar is otherwise completely original and I would love to get the original switch back in there.
  12. 63telemaster
    63telemaster Tele-Meister
    A word of warning, if you clean the old switch with servisol or similar take care with the white plastic centre part as it can crack......ask me how I know :cry:
  13. pcasarona
    Auburn, AL
    Thanks for the advice. I'll be careful with that. Any alternatives safer than servisol?
  14. pcasarona
    Auburn, AL
    Put the switch in today. Works fine! A little stiff switching from middle to neck position. I would have thought that a warn-out switch would have been loose and sloppy, just the opposite. Can't figure out why anyone would have taken it out. Maybe they didn't like how stiff it was?
  15. Redd Volkaert
    Galax, Virginia
    You can take the spring off and stretch it, and that will ease the stiffness. Spring steel so some tugging is required.
    And any tuner cleaner or isopropyl alcohol will work too with a tooth brush, to clean the switch
    Tedzo and pcasarona like this.
