Help...amp losing volume but not gain
Discussion in 'Amp Central Station' started by schenkadere, Jun 16, 2021.
  1. schenkadere
    schenkadere Friend of Leo's
    NY
    I have a little Randall Diavlo 5W combo that I love. It never leaves my bedroom and never gets played super loud. Last night, while playing, my volume would fade out and then come back, but my gain/distortion level would pretty much remain. Any ideas? I'm assuming a tube? They're JJs and don't have a ton of playing time on them.
  2. northernguitar
    northernguitar Friend of Leo's
    North of Toronto
    Output tube? Tubes can die, right outta the box.
    davidchagrin, schenkadere and uriah1 like this.
  3. ISmellSmoke
    ISmellSmoke TDPRI Member
    Portland, OR
    I suspect the antics of an evil clown.
    Or perhaps the speaker connection has somehow become less than optimal.
    schenkadere likes this.
  4. schenkadere
    NY
    The power tube I assume.
  5. schenkadere
    NY
    maybe the clown, but the amp never even moves...I can't imagine a speaker connection failing.
  6. Greg70
    Greg70 Tele-Meister
    St Louis, MO
    Sometimes a dirty tube socket can cause things like that. I would try removing and reinstalling the tubes a few times and see if it changes. Be sure it is off and unplugged when you do that so you don't get any loud pops.
    schenkadere and northernguitar like this.
  7. northernguitar
    North of Toronto
    Yep. That’s where I’d start.
    schenkadere and Chicago Matt like this.
  8. Les Paul lover
    Les Paul lover Tele-Holic
    England
    I suppose the power valve is on its way out. Assuming you get your gain from the preamp only, that would explain why your gain stays the same (preamp gain, from ECC83) and why your volume is fluctuating (power amp provides volume amplification before adding their own overdrive when pushed hard).
    Whilst I don't really think that's it re: the speaker connection (the volume wouldn't fade in and out, it would be on/off), it's worth keeping in mind that connections don't need to move to possibly fail. A poor solder joint might be affected by the raising temperature within the amp chassis as it's being played, or component might suffer heat related failure.
    Lots of things can happen, but here, replace the power valve 1st.
  9. schenkadere
    NY
    I actually have an extra tube to test and verify this. Thanks guys!
    northernguitar likes this.
  10. dan40
    dan40 Friend of Leo's
    Richmond Va
    Not sure if this amp has an effects loop or not but they can cause issues similar to yours. If plugging a cable directly into the send and return jack (no pedals connected, just the cable) fixes your problem, it's a good bet the switch contacts in the jacks need a good cleaning.
  11. Daytona.57
    Daytona.57 Tele-Meister
    Calabogie, On, Canada
    I was experiencing, the same issue with all my amps and my partner's large frame quilting machine.
    The volume of the amps and quilting motors, would speed up and slow down.
    A contractor metered the home electrical voltage, and measured fluctuations, from 80-138V, at the outlets.
    I tried surg protection and it did not work, so, we aquired a Furman AP-1800 voltage regulator and we haven't had a problem since.
    It is a relatively, inexpensive solution, considering the replacement costs for my amps, guitar pedals and quilting machines. The Furman AP-1800, has banks of outlets, for analog and digital gear. It regulates the voltage to 120V, +/- 3V.
    We unplug the Furman and all all other expensive equipment, including my pedalboard, when not in use.
    Edit: correct auto correction on upload.
  12. schenkadere
    NY
    It does have an effects loop and I'll look into that too...thanks...waiting for the weekend.
    dan40 and northernguitar like this.
