Lowerleftcoast
They are not polarized. One leg will connect to the outer film which can act as a shield so some builders will try to identify the outer foil leg. There are several threads discussing *how to*. I doubt the orientation of the coupling caps in a 5F2A will result in any improvement in noise level. Their position on the board has a good distance from other components so the shielding property will likely not be an advantage.
