Help: 65 Princeton Reverb Kit Build Problem
Discussion in 'Amp Tech Center' started by trber, Dec 28, 2019.
  1. trber
    trber Tele-Meister
    NorCal
    All,
    I have built my Christmas gift, but no sound. All the voltage tests have worked fine and are to spec. When I tried playing through it, however, no sound except at full volume and then, just a faint, fizzy sound. I will contact the support crew on Monday from the Kit company, but hoped to get it sorted this weekend, so I can hear the sweet sounds!
    Any help/advice would be hugely appreciated!
    Ideas?
  2. trber
    trber Tele-Meister
    NorCal
    I should add:
    -- the speaker cable was swapped to eliminate a problem there. No luck
    --I believe all joints are soldered and OK.
    --I have checked for loose joints/connections and found none.
    --I believe all pots are correctly wired, and have checked them as well.
    I wonder if there is something I am not thinking about that could be the root cause.
  3. tubejockey
    tubejockey Tele-Holic
    the bozone
    Pics would be helpful here.
    Do all the tubes light up? Did you double check wiring of the jacks? Start at output and do "pop tests" on each plate and grid until you get to the input.
  4. gaddis
    gaddis Tele-Afflicted
    New York
    Do you have a voltmeter? If so, you need to measure the voltages at critical points in the circuit. I’m sure your kit instructions must give you information on this. If you decide to go ahead with this, please be extra careful. Amps have dangerous voltages.
    Wildcard_35 and trber like this.
  5. trber
    trber Tele-Meister
    NorCal
    Thank for the suggestions! I will check on all mentioned, and look up a "pop test" as I am not sure what that is.
    Also, happy to provide pics, but did not want to add a bunch of irrelevant clutter. Any specific areas or just do the whole board?
    Thanks again...hoping to get this sorted out!
  6. trber
    trber Tele-Meister
    NorCal
    Hi!
    Yes, I have checked the voltages and they are fine, according to my readings and the instructions. I could have missed something though, so will double check. I also am being very careful with the voltages...gotta go to work soon, and family waits! Thank for you advice and concern. Appreciated.
  7. trber
    trber Tele-Meister
    NorCal
    Jack's and wiring diagram. [​IMG][​IMG]
    Sent from my SM-G955U using Tapatalk
  8. tubejockey
    the bozone
    What happens if you push the plug all the way in?
  9. corliss1
    Lansing, MI
    'pop test' means that should hear a little pop or noise through the speaker when you make contact with the plate of the tubes. For example, if you poke pin 1 of a 12AX7 with your voltmeter probe, you should hear a noise through the speaker.
    @tubejockey - that would be pretty epic if the guitar cable wasn't all the way in and that was it :D
    Do you hear any hum/buzz from the speaker at all? Even at idle there should be a hint of noise that the amp is running. If not, there's something in the output.
    Might be time to learn some more troubleshooting skills, such as making a signal tracer, to see and hear where the audio stops getting through the circuit.
    trber likes this.
  10. trber
    trber Tele-Meister
    NorCal
    That was just in the picture. It was all the way in for testing and nothing. I am currently looking at the speaker jacks again.
  11. trber
    trber Tele-Meister
    NorCal
    Thanks on the pop test definition. I'll check.
    No noise at idle. All quiet.
  12. trber
    trber Tele-Meister
    NorCal
    I was getting a pop on v1, pin 6, but nowhere else. I checked pin 1 but no pop. What might be causing that?
  13. BigDaddy23
    BigDaddy23 Tele-Holic
    Do you have approprite voltage at the V1 plates (pins 1 & 6)?
    It would be good to have pics of the entire board, tube sockets, pots and output jacks. It will be something simple.
  14. trber
    trber Tele-Meister
    NorCal
    A start...[​IMG][​IMG][​IMG]
  15. trber
    trber Tele-Meister
    NorCal
    More... not sure if you can see what you need. [​IMG][​IMG][​IMG][​IMG]
  16. trber
    trber Tele-Meister
    NorCal
    Back side. [​IMG][​IMG]
  17. trber
    trber Tele-Meister
    NorCal
    I tested pins 9 and 4-5 and found 3.2 v AC.
  18. tubejockey
    the bozone
    Do your pop tests from the output to input. Pop should get louder as you go. Make sure volume and tone pots are turned up, and compare your readings to the voltages on your schematic.
    Wally and trber like this.
  19. rolandson
    rolandson Tele-Holic Silver Supporter
    Cascadia
    Relax @trber ... Everything will sort itself out.
    An amp build without problems like these would create an imbalance in the universe, causing calamity of unimaginable proportions throughout space-time.
    I called a mate I regularly accompanied one day, utterly flummoxed over the sudden failure of my Strat to provide signal. I checked everything and ... nothing.
    Then his spouse picked up and suggested I try the volume knob. I told her the amp was fine and she said:
    "No, the guitar's volume knob Einstein."
    I had to think about it for a moment...then the quintessential "oh..."
    To which she replies: "I won't tell you who else had a meltdown over this very thing. I know now why Leo put knobs on those things...to convince you geniuses your guitar is broken and buy a new one."
    trber likes this.
  20. trber
    trber Tele-Meister
    NorCal
    I placed a red wire by the schematic where I am not getting any voltage reading on that eyelet and the next few to the right.
    The green wire on the schematic is where I am getting pops, the one to the right and left of the wire. No others pop, if that's what im supposed to be checking.
    Thanks all! [​IMG]
