Topjimmy74
Hello everyone. Long time lurker first time poster. I've been getting more and more into tube amps. Going to be building a RobRob Deluxe very shortly. Along the way of learning, and some inherent GAS, on that project, I ended up purchasing an amp that was built by a local EE sometime around 1990 from what I understand. I don't know anything more about its history. I'm wondering if any of the gurus here can identify the type of circuit it's based upon by reviewing the three attached photos. Apologies if this is a silly question; I'm new and learning, but not knowledgeable enough to figure this one out at the moment. The OT is a Stancor A-3311 if that helps. The amp works as is, based on very limited testing shown to me by the seller. I intend to replace the plug (adding a ground), input and output connections and the caps in the near term, but probably not much else (unless you have any great ideas
. I'm perplexed by some of the chassis grounding. Anyway, it's a joy to look and learn with these amps. Any helpful tour guide services you can provide are greatly appreciated! And also, yes, I understand the safety considerations involved in working on these even though I'm new. Thank you all for your time and any help.
All the best,
Leo
All the best,
Leo
