Headstock Thickness
Discussion in 'Tele Home Depot' started by Laren, Oct 20, 2020.
  1. Laren
    Laren Tele-Holic
    West Somerset
    Hi guys,
    I'm building a Cabronita sort of thing and decided to follow the plans which had the headstock thickness at 13mm. Now when I was checking earlier my tuners don't tighten down that much, they'ed be fine in a 15mm headstock.
    OK I can get some washers that would 'fill' them out but what I can't seem to find is some tuners that would fit on a 13mm headstock.
    Are they called something ? Something I could lookup?
    Many thanks,
    Paj
    The neck 'cos I know you like pics :)
  2. pypa
    pypa Tele-Holic
    new jersey
    Dumb question: are your plans calling for a 13mm headstock with or without an added veneer?
    If it were me, I'd build to a standard thickness because of better tuner availability and strength.
    Peltogyne and crazydave911 like this.
  3. Laren
    Laren Tele-Holic
    West Somerset
    No veneer no. I should pulled myself at the time. I think there's two choices,
    1. Washers
    2. Get the threaded insert on the grinder and lose 1 or 2 mm
    I shall keep pondering. Of course I've already drilled the 10mm holes :oops:
    crazydave911 likes this.
  4. crazydave911
    East Tennessee
    I've seen tuner washers on Amazon and Ebay but they aren't easy to find. I build to 9/16" normally which seems to work well. I know that is close to 14mm but a little larger. I'm not big on following plans to that degree as I normally build non standard scale lengths and wood. YMMV but I massage such things to my needs not the other way around
    Dave
    Laren likes this.
  5. Freeman Keller
    When I built the double neck I thicknessed the heads (with veneers) to exactly 1/2 inch, which was the spec for the tuners that I intended to use. That was marginal, a couple of them were slightly loose. I considered adding a back strap but instead I added a second washer (purchased from LMII) and they are working fine. In the past I had always thicknessed to 9/16 but I thought I could go a bit thinner on these - it was a mistake to not have them in my hand and actually measure them (duh)
    Macrogats, crazydave911 and Laren like this.
  6. guitarbuilder
    The Ed Hawley neck, which is my go-to tele neck drawing, specs out the tele peghead thickness at .580". That's what you should shoot for in metric if your Cabronita -like guitar has a F style peghead. I'd say your drawing is off.
    His drawing can be found here as neck PDF.
    https://www.gitarrebassbau.de/viewtopic.php?t=6
    His thread is one of the most viewed threads here:
    https://www.tdpri.com/threads/53-cnc-build.83286/
  7. ctmullins
    ctmullins Tele-Meister Ad Free Member
    MS Gulf Coast
    Hardware store chrome washers work fine.
    Gaz_, trev333 and crazydave911 like this.
  8. tewiq
    tewiq Tele-Meister
    Granby Qc. Canada
    I did the same thing once , a file was my best friend. :)
  9. Davecam48
    Davecam48 Poster Extraordinaire Ad Free Member
    Queensland Australia
    Hear! Hear! It's called "Tweeking! If you're like me and have never built "A Kit Guitar" you have to comprise and adapt a heck of a lot because not everything you need will be in front of you. No-one will ever know that those washers or screws or whatever are not genuine Fender or Gibson supplied.
    Whip down to your local hardware shop and take a tuner with you and select what you need!!!
    DC ;)
    tewiq and crazydave911 like this.
  10. Davecam48
    Beautiful work Freeman!!!!
    DC
  11. otterhound
    otterhound Poster Extraordinaire
    Manheim Pa.
    Since my design uses side mounted tuning machines , I need at least 3/4" headstock thickness to mount them . I really don't see what all the fuss is about .
  12. Laren
    Laren Tele-Holic
    West Somerset
    Sorted with my belt sander :)
    crazydave911, trancedental and Gaz_ like this.
  13. smoothrecluse
    smoothrecluse Tele-Holic Silver Supporter
    Panther City, TX
    I’ve had to grind down the threaded ends before on a cheap kit guitar. It worked just fine.
