Headstock sandwich-- strong enough?
Discussion in 'Tele Home Depot' started by ppg677, Jun 10, 2019.
  1. ppg677
    ppg677 Tele-Meister
    WI
    Any thoughts as to whether this is a terrible idea? I tried applying downward pressure and sure enough the wood glue joint separated at the end grain joint. Then I put some CA glue in the joint and now its not budging when I apply similar downward pressure. I think the CA glue is pretty effective on the end grain joint...
    String tension will pull it the other way and strength should be fine. Only risk is how well it handles an accidental drop or something.
    Don't ask how I got to this point...
    Total headstock thickness is 0.55". Base wood is .26" maple with the .29" top sandwiched on.
    Tonetele likes this.
  2. guitarbuilder
    I'd say it'll be OK and hold, but end grain to end grain doesn't make a strong joint. You could also see the dis-similar wood grain direction move too, leaving a bit of a gap or more pronounced glue line.
  3. jvin248
    jvin248 Poster Extraordinaire
    Lions & Tigers oh Mi !
    That end grain right at the point where the carving will run out, the nut pressure and headstock bend-rotation point, it's kind of suspect. Could be fine for years, or might not.
    Before you go to the extra work of the fretboard, frets, carving the back of the neck, sanding, finishing, ... you might just get a new stick of lumber and start a new neck setting this one aside.
    I had a couple of necks I bandsawed the headstock too thin, maybe I'll convert them to headless sometime and use them...
  4. Ronkirn
    Jacksonville, FL
    yes it'll be fine, the way the string's tension is applied to the headstock will not be enough to cause a fault...
    rk
    DrASATele and Tonetele like this.
  5. TenaciousP
    TenaciousP Tele-Meister
    Arkansas
    I’d be afraid that carving the back profile of the neck and the transition into the headstock would start getting into the 90 degree area of the joint. It may only leave a narrow and thin section of the base wood at the centerline.
  6. Tonetele
    South Australia
    I've seen Colt W. Knight try to break a Telecaster body and he's a BIG guy. Yes it eventually broke after him slamming it on his bench but did not break on the glued centre line. See it on Youtube.
  7. Ronkirn
    Jacksonville, FL
    What's Colt doing these days anyway?? Anyone keep up with him?
    r
  8. RogerC
    RogerC Poster Extraordinaire
    Oklamerica
    Been there. Here's how I fixed it, and that guitar is still going strong.
    eallen, 2blue2, old wrench and 2 others like this.
  9. guitarbuilder
    I e-mailed him at his place of employment a few months ago and got no response.
  10. Jim_in_PA
    Jim_in_PA Tele-Holic Silver Supporter
    SE PA near New Hope PA
    The undercut or similar as shown in a previous post makes for a stronger glue joint if you must laminate these two thicker pieces. The alternative is to just veneer the face to get the benefit of the figure without any compromise in strength. Regular veneer likely will not require you to reduce the thickness of the headstock other than a few passes of a hand plane. Thick veneer (1/16"/1mm) should probably be taken into account when thicknessing the base headstock.
    That said, I don't think that the joint illustrated, if glued properly, will have adverse qualities when the direction of string tension is considered.
    Wally likes this.
  11. Ronkirn
    Jacksonville, FL
    Do ya know if he ever got his Graduate degree.. Masters if I recall?
  12. guitarbuilder
  13. DrASATele
    North of Boston
    I forgot about Roger's mishap.It's still rocking though, awesome.
    I think the others for the most part have said it, you should be good for the most part. Time will tell if any movement happens. It's a nice save attempt. I might still work up another neck along with this one in case things go sideways.
    I always associate Colt with Finishing when it come to the TDPRI. He really stopped posting a while back, which is too bad his contributions here were and still are impactful.
    Just saw the newer post, I forgot he's a modern farming man now. Dr, Colt sounds like the name of a gun parts company or guitar.
  14. Ronkirn
    Jacksonville, FL
    Yeah, he was a great contributor.... I haven't chatted with him in a few years.... and miss his comments greatly...
    r
  15. TRexF16
    Tucson
    Brilliant Roger, the old "Don't try to hide it, make it a feature." approached to mishaps. Nicely done.
    And I miss Colt too. Might ought to drop Dr. Knight a line. We had discussed getting together for a nip or two of Kentucky's finest when he was in Tucson but I ended up overseas a lot and like so many things we talk about, it never happened.
    Cheers,
    Rex
  16. philosofriend
    philosofriend Tele-Holic
    Kalamazoo
    It's a bolt-on neck, right? Might as well finish it then. Great detective work that led to the CA glue.
    But you know how they say to loosen the strings when you load your guitar on an airplane? On that neck I would leave them tight!
    That Maple looks nice, just keep going.
  17. ppg677
    ppg677 Tele-Meister
    WI
    Interesting...I suppose I could cut a slot at the current joint, with a table saw, and glue in a piece of contrasting wood. Then it would be two face-grain-to-end-grain glue joints rather than the single end-grain-to-end grain.
    I did make a second neck as well with a 1/8" veneer. This one fits a bit nicer in the neck slot.
    2blue2 likes this.
  18. Freeman Keller
    I would probably install two splines in the back of the head on each side of the truss rod. Most of the time they are used with cross grain failures (Gibson style) but it wouldn't hurt here.
    old wrench likes this.
  19. ppg677
    ppg677 Tele-Meister
    WI
    Great idea. Thanks!
  20. old wrench
    old wrench Tele-Afflicted
    corner of walk and don't walk
    It's not a good situation, but I don't think it's as bad as it looks at first sight :).
    Physics are actually working in your favor, so I think you'll be OK.
    Once you're strung up, string pull will put the end grain joint in compression, and the tuners will help tie things together too.
    There have been a few times, when I've thought that I've committed a truly novel and one of a kind f-up, some kind soul has come along and said, "yeah, that was pretty dumb, but it's not that bad, I did that myself one time" ;).
    Best Regards,
    Geo.
    2blue2 likes this.
