Head scratcher...
Discussion in 'Amp Tech Center' started by RidiculousWonk, Jul 24, 2020.
  1. RidiculousWonk
    RidiculousWonk TDPRI Member
    Southern New Jersey
    I am having a noise issue that I can't run down and am seeking the wisdom of the forum. I have a Dr. Z Jetta and a Boss Katana 100. When playing either my Player Series Tele or my Vantage VP795 (humbuckers), I get a crackle out of both amps on some sustained notes (open E and G are two biggies). The crackle is more intense the louder the guitar volume is turned up. The tube amp did need new preamp tubes a few weeks back, but the typical bad preamp tube noise is gone and this is something different.
    Straight in, through my pedal board, different cables, no change. I have a TrippLite voltage regulator with good noise filtering, so I don't think it is a power issue. I have a lot of stuff in my basement practice space (PC, Roland digital piano, dimmer lights), but turning off and unplugging those things has no effect. It almost feels like harmonic feedback, but it is an unpleasant crackle as opposed to what I'd consider typical guitar feedback. I can actually hear something rattling in my drop ceiling on those same notes that cause the crackle. The last thing I'm going to try is physically moving the amps to another spot in the house to see if that changes things.
    Besides trying a different room, anyone got any suggestions?
  2. gkterry
    gkterry Tele-Afflicted Silver Supporter
    the Telecaster Forest
    Have you tried without the voltage regulator? The can go bad. Can you peek into the drop ceiling while playing to see what may be up there?
  3. RidiculousWonk
    Southern New Jersey
    I did try without the voltage regulator. Forgot to mention that...sorry!
    As for peaking in the ceiling, I haven’t tried to look. I can really hear it near the recessed lights. I can’t tell if it’s in the fixture, ceiling, or the light bulb filament. I get the ceiling rattle at the same time I get the crackle from the amp.
  4. RidiculousWonk
    Southern New Jersey
    I have discovered that the bridge pickup in my tele and both humbuckers are slightly microphonic. I am not getting that typical squeal, but maybe that is causing the crackle at loud volumes. I don't seem to have any issues when I'm straight in to my AXE I/O or using headphones on the Katana.
  5. Lowerleftcoast
    california
    Are these amp heads that are played through the same speaker cab?
    It may be a speaker problem.
  6. Boreas
    Boreas Friend of Leo's Silver Supporter
    Adirondack Coast, NY
    Don't laugh, but my insulin pump can create a crackle noise. I also have a heating pad that does something similar. I doubt it is related to your guitars or amps. I think it is some nearby electronics switching on/off.
  7. RidiculousWonk
    Southern New Jersey
    Both amps are 1x12 combos. I also tried moving one amp to another part of the house. Same result. I might try a pickup swap and see how that goes. Probably try
    To pickup something used that I know is potted. I’m not sure if any of the pickups from my two guitars are potted from the factory.
  8. Lowerleftcoast
    california
    Two different guitars. Two different amps. Two different rooms. With and without voltage regulator/pedals. Everything is different, yet same problem.
    You are right... *Head scratcher*.
  9. Lowerleftcoast
    california
    Ahh...
    Static electricity.
    Try bending the cables or slapping them on the ground.
  10. Boreas
    Air conditioner? Fan?
  11. Wally
    Are you rubbing the pick guard with your fingers and developing static discharge?
  12. BobbyZ
    BobbyZ Doctor of Teleocity
    Snellman MN
    That one almost had me tearing an amp apart, thankfully my brother was here at the time. He's played Teles longer than me and told me all I needed to do was rub a dryer sheet on the pick guard. Don't remember that ever happening with the Les Paul and Strats I played prior to getting my first Tele.
  13. Treadplatedual
    Treadplatedual Tele-Holic
    Indianapolis, IN
    This. Where is your cell phone during all this playing?
    Boreas likes this.
  14. Wally
    the solution is closer to the guitar world than the laundry room. Cleaning and Polishing the pick guard cures the situation.
  15. BobbyZ
    Snellman MN
    When I got my first decent guitar, a Les Paul, I was 17 and cleaned and polished it all the time. My cleaning and polishing phase didn't last real long. :)
  16. Wally
    Keeping a guitar clean and polished is important, ime, especially with nitrocellulose finishes. I have always used Gibson polish on nitro finishes. Old cowboy saying....’that horse looks like it has been rode hard and put up wet’. Good care pays off, imho/ime, and neglect detracts from condition and value.
    BobbyZ likes this.
  17. johnnylaw
    johnnylaw Tele-Afflicted
    New England
    Turn off your cell phone?
    Mine can make gear noisy sometimes.
  18. RidiculousWonk
    Southern New Jersey
    I finally figured it out! The Humbuckers are microphonic. Still kept hearing the noise on the tele. After striking out with the dryer sheet, I kept on digging. I wasn’t getting a typical ground hum when not touching the strings. Nonetheless, I took out my multi meter just to double check my grounding. Bingo! I found that I was having trouble getting consistent ground continuity on the bridge. It turns out the wire I was using to connect my shielded cavities and bridge was not making good contact anymore. Once I fixed the ground connectivity of my cavities and put better contact to my bridge and pick guard, the intermittent static disappeared. Problem solved!
    Thanks to all who made suggestions! Now I can finally practice without going nuts with the static!
  19. Collin D Plonker
    Collin D Plonker Tele-Afflicted
    Delaware
    Glad you fixed your issue.
    BobbyZ likes this.
