Boreas
The misaligned neck can usually be simply adjusted by loosening the neck screws, straightening the neck, then re-tightening. This is usually one of the first steps in a proper set-up on a new guitar.
Although in your case, I believe something is askew on your bridge/saddles. Something is out of position. May be simple, may be bad. Would need more pix to diagnose. But if it is going back, it doesn't matter, unless your replacement was the next in line at the factory!
