Has anyone ever built an amp cabinet using T-slot extruded aluminum?
Discussion in 'Amp Central Station' started by Sequimite, Sep 21, 2021.
  1. Sequimite
    Sequimite Tele-Meister
    Sequim, WA
    Planning my RobRob Deluxe build for this winter. My so-called wood worker "friends" have not put themselves forward to help with the cabinet.
    Fate intervenes. I bought two pallet loads of Boeing display cases for $25 at an auction because I had plans for the four smaller cases. Five other cases were still full of hardware including a case a bit short of seven feet tall which contained a bunch of T-slot aluminum beams and connecting hardware.
    I would be very happy with a unique looking amp so I'm pondering using this stuff to make a frame and then bolting the wood panels on. So.... has anyone done anything like this?
    Jakedog, Coffeemutt and mkdaws32 like this.
  2. corliss1
    corliss1 Poster Extraordinaire Platinum Supporter
    Lansing, MI
    It would look kinda like a Roland Jazz Chorus :D
    No reason it couldn't work out well.
    Crobbins and mkdaws32 like this.
  3. bebopbrain
    bebopbrain Tele-Meister
    New York City
    Should really be deluxe; there is no down side.
    mkdaws32 likes this.
  4. USian Pie
    USian Pie Tele-Holic
    North Texas
    That actually seems kind of genius. It's like a flight case and speaker cab combined.
    Should be super-tough. If the wood panels are quality, I don't see why it wouldn't sound good.
    Wobbles likes this.
  5. Sequimite
    Sequim, WA
    If I go this route I'm going to make the cabinet bigger than standard. It also occurs to me that with a bolt on speaker baffle I could swap in other baffles to try a 15, two 10's so I'd want to make it big enough for those other speaker configurations.
    mexicanyella and wrathfuldeity like this.
  6. ce24
    ce24 Poster Extraordinaire
    Idahoastan
    Put a drawer in the bottom!
  7. wrathfuldeity
    wrathfuldeity Tele-Afflicted
    Turdcaster, WA
    Make ports that slide open/close
  8. printer2
    And a beverage holder.
    AxemanVR, guitar_paul1 and kafka like this.
  9. Jakedog
    Jakedog Telefied Ad Free Member
    The North Coast
    Why use wood? With that frame, go full exotic and see how Plexiglass sounds. Get the good thick stuff, and build a note aquarium.
  10. kafka
    kafka Friend of Leo's
    Closer than you'd expect
    It's bolted, but it's still friction holding it together. It might be OK if it never moved, but I wouldn't want to gig it.
  11. guitar_paul1
    guitar_paul1 Tele-Holic
    washington state
    I used to use that stuff when I worked there. Super pricey! Good find. Heavy for a cabinet, though.
    I sure used to love their surplus store back when it was open.
    Did the tub skid come as part of the lot?
  12. schmee
    Dont forget a swing out bar with bottle holders, fridge, and a stereo.
  13. Sequimite
    Sequim, WA
    No. they made it clear that I was not to take the tub skid.
    I am thinking of one panel of acrylic to show the electronics and glowing tubes.
    When I'm done figuring materials the weight will be decisive in whether this is a "go" or "no go".
  14. f69tele
    f69tele Tele-Holic
    Hallettsville, TX
    Peavey made a series of PA speakers and Bass Heads/Cabinets back in the 80's under the "International Series" I believe... they were of the "flight case" type construction.
  15. Sequimite
    Sequim, WA
    f69tele likes this.
  16. Sequimite
    Sequim, WA
    Here is the front and back of my guitar amp: each is 24" x 22" with clear acrylic panels with white protective film.
  17. Dan German
    Dan German Doctor of Teleocity
    Left of the Left Coast
    6063 has the best toanz.
  18. dsutton24
    dsutton24 Doctor of Teleocity Ad Free Member
    Illinois
    It will be a rattling mess. The corner pieces are not at all vibration resistant.
    Wally likes this.
  19. Sequimite
    Sequim, WA
    Please state your experience that leads you to this conclusion. I was more worried about the acrylic panels, but they all have rubber gaskets.
  20. NoTeleBob
    NoTeleBob Friend of Leo's
    Southwestern, USA
    Even if that is true, you could have all the seams welded (inside) that you don't need removable.
