Harvard in a 5F2A Chassis Build
Discussion in 'Shock Brother's DIY Amps' started by James Knox, Nov 22, 2020.
  1. James Knox
    James Knox Tele-Holic Silver Supporter
    Phoenix
    I am learning that Solving Problems is a big part of building Amps. Now, to solve the problem of “cutting a Big hole in the chassis” for the Previous wrong Power Transformer.
    I had some washers laying about and figured out that I could put a washer on either side of the chassis to bite down and hold the PT in place. Like a bracket. I tightened everything down and that Tranny ain’t goin’ nowhere!
    3D092593-6BE3-4590-9A29-EB303B835A4B.jpeg CDEBB909-C79B-4421-8D35-7E2208C30A47.jpeg
  2. BigDaddy23
    BigDaddy23 Tele-Holic
    Excellent! I’ll be watching this build!
    BTW - my bias resistor is 100K with a 10k bias pot with that tranny. I reckon I have a 27K resistor to ground off the pot.
    James Knox likes this.
  3. James Knox
    Phoenix
    Today I got the Diodes, Grid Stoppers and Screen Resistors on the Octals and mounted them. V1 and V2 sockets in ready for filaments tomorrow. Loose fitted the Bias Pot, 1/10 Power Mod Resistors and made sure the Board cleared everything. My first Hoffman Board. Man, that thing is nice!
  4. James Knox
    Phoenix
    yeah, I have a 10k pot there. The fixed bias part Of this build is the “new territory“ for me. I’m going to study up on it tonight. It’s still a little confusing to me.
    BigDaddy23 likes this.
  5. James Knox
    Phoenix
    Regarding the 1/10 Power Switch Mod, I put the Fuse on the bottom of the Chassis which freed up the hole on the top for the SPDT ON/ON Switch.
    Does it look like I have this wiring scheme right?
    19199243-DB22-40C8-AACE-7E85DC1F69B0.jpeg 9A8590CA-A458-4496-80EE-137EEDD31A2A.png
  6. James Knox
    Phoenix
    Today I wired up the 1/10 Power Switch, Rectifier Tube Socket, Lamp Assembly and Heater Filaments ran...
    755E7931-504E-42F2-8F2A-83F6B5DA6EED.jpeg 0E7D1DB1-2526-4C63-B80F-D686937F242A.jpeg
    Tele Slacker, awasson and rjtwangs like this.
  7. BigDaddy23
    Looking great, mate!
    Have you got heat transfer paste under those big resistors? It's a good idea to ensure they operate to their rating.
    awasson likes this.
  8. James Knox
    Phoenix
    No, but they are bolted down tight. I don’t have any. How important do you think it is?
  9. BigDaddy23
    I think it is required for correct rating as it takes up any air gap. It’s the white paste that you see between big transistors and their heat sinks in SS equipment. I used it in my attenuator builds where I had the big 25 and 50w resistors.
    It would be easier to chuck some in now before that chassis fills up more!
    awasson and James Knox like this.
  10. James Knox
    Phoenix
    Good point. I’ll get some! Thank you!
    awasson and BigDaddy23 like this.
  11. BigDaddy23
    It’s handy gear to have - you only need a small amount......a little goes a long way! Just wipe the excess ooze out
  12. David Barnett
    And by small amount, that means the thinnest film possible. The least amount that will spread out to fill the area when you screw them down.
  13. Kevin Wolfe
    Kevin Wolfe Tele-Holic
    Lakeland FL
    @James Knox, something you may be interested in trying on your builds.
    The terminals on the topside of the tube sockets, you can bend them downward at something like a 45 degree angle and get yourself more room to manipulate all that wire to decrease the chance of shorting something out.
    Can’t remember where I learned that, but it helps me anyway.
    Edit: Oh, and by the way, nice build.
  14. James Knox
    Phoenix
    Ive bent them here and there when there is a lot going on. I’ve never bent them all at a 45 degree angle. It’s actually a cool idea. One could do it prior to mounting in the chassis.
    I saw this diagram from a Fender Service Manual and wondered if they were bending them....
  15. James Knox
    Phoenix
    When wiring up V1, since I am using a 12AY7, do I just leave the second triode empty (no wires)? I seem to have seen something about “parallel” wiring both V1 triodes.
  16. Kevin Wolfe
    Lakeland FL
    They probably won’t fit through the holes if you pre-bend them.
    Some circuits do parallel the triodes, but others do not. I’d follow the schematic. Someone with more experience than I should be able to answer that. I myself, have never substituted a dual for a single triode.
  17. gabasa
    gabasa Tele-Meister
    Toronto, ON
    I'm just collecting parts for a Harvard build myself. I didn't even know that this part of the forum existed until now, so I'll also be starting up a build thread soon.
    Subscribed and watching!
    screefer, James Knox and Kevin Wolfe like this.
  18. Emiel
    Emiel Tele-Meister
    The Netherlands
    Nice build! Subscribed!
    I'm using the very same transformers in a DIY 5F10 Harvard. The lower 275V tap gets you right into 10% of the original 305V measurement. After reading jsnwhite619's comments I'd like to try the hotter 325V tap, to put it more into 5F11 territority. Johan Segeborn did a Youtube video on an original 5F11 and it's rocking! Mine doesn't do that, it's a bit more compressed and 'congested'.
    Kevin Wolfe and James Knox like this.
  19. James Knox
    Phoenix
    Since I’m only doing two instruments inputs (Rather than the Harvard three) do I just wire them like a two-input 5F1 Champ? I would like to attach the resistors directly on the tube socket and use shielded cable.
    Kevin Wolfe likes this.
  20. Kevin Wolfe
    Lakeland FL
    A 5e3 has two sets of 2 inputs. That would work. If the Champ inputs use 2 68k resistors, that would work as well.
