Harvard and Deluxe Builds - My first TDPRI Journal
Discussion in 'Shock Brother's DIY Amps' started by gabasa, Nov 27, 2020.
  1. gabasa
    gabasa Tele-Meister
    Toronto, ON
    Hey all, I've been working on these amps lately whenever I've got the time. I've read a number of times that 22awg wire is fine for everything and usually 20awg or 18awg is used for the heaters. I have a quick question about this though. Because the voltage rating for cloth wire is lower than PVC, is it ok to use 22awg cloth wire for the two wires that connect to the standby switch? Basically, rectifier tube to standby switch and standby switch to B+ connection on eyelet board.
    Thanks.
  2. David Barnett
    That's what you'll find in an old Fender.
    But why would you need a Standby switch in a Harvard or a Deluxe?
  3. gabasa
    gabasa Tele-Meister
    Toronto, ON
    Because there's a labeled Standby hole in the chassis. Thanks for the info!
  4. Blue Bill
    Gabasa, I just found this thread, I'm enjoying the show. I agree with you: It's fun to spend a few extra bucks on cool caps. The money you save by building it yourself pays for hot-rod components. Those cabinets are sharp-looking, too.
  5. gabasa
    gabasa Tele-Meister
    Toronto, ON
    Thanks for that, I'm having a lot of fun here!
    I agree, spending extra on some components (and less on others) can make things really fun and give you something unique. I figure this 5E3 will cost me a grand less than a something like Clark, Milkman or Swart, even with the premium caps. No complaints!
    Blue Bill likes this.
  6. Lowerleftcoast
    california
    22 AWG can carry the current. Iirc, the cloth cover is rated for 300V. As pointed out Fender used cloth covered wire for that part of the circuit back in the day.
    Are you willing to be liable for the fire damage when the inspectors decide under-spec cloth covering was contributory to the fire?
    Use the *Standby* hole for a mute. Nobody will know but you. Hah!
    gabasa likes this.
  7. gabasa
    gabasa Tele-Meister
    Toronto, ON
    This is where things get confusing. So many posts everywhere saying that 22 awg cloth wire is ok everywhere, even the heaters, but I get what you're saying.
    Do you really believe a fire hazard exists? I can swap it out with PVC wire if there's a genuine safety issue.
  8. Lowerleftcoast
    california
    For such things I use the 22AWG 600v cut-off remnants from the PT.
    Any time electricity is used there are hazards. Cover your fannie.
    gabasa likes this.
  9. gabasa
    gabasa Tele-Meister
    Toronto, ON
    Just to add to the confusion, there's actually no true voltage spec on Gavitt cloth wire, or any other cloth wire for that matter. Nobody would ever stamp an official safety certification on it. Gavitt's has an extra textile layer underneath the outer cloth layer, I don't know if this makes it able to handle more or not.
    You'd have to be willing to be liable for fire damage even if you use it at 50V. We should ban cloth!
  10. gabasa
    gabasa Tele-Meister
    Toronto, ON
    I will, and I appreciate your input. Looks like I have some rewiring to do in my 5E3, which is almost done.....
  11. gabasa
    gabasa Tele-Meister
    Toronto, ON
    I've put some thought into this. I'll make sure that everything in my current builds up to the B+ dropping resistor or choke is wired with the 600V offcuts from my PT, but going forward, I might spring for solid core copper/teflon wire. It would be cool to try one day.
    Hey, I thought I said I'm done building after these?!?
  12. gabasa
    gabasa Tele-Meister
    Toronto, ON
    Done! Amp is now safer than it was!
    2L man likes this.
  13. gabasa
    gabasa Tele-Meister
    Toronto, ON
    Amp #1, the 1x10 5E3 is done. It's not an exact 5E3 with the smaller speaker, choke and screen resistors, but man does it ever sound great. Everything works perfectly, it runs nice and quietly and the overall sound and feel is quite incredible. So rich, organic and oozing with harmonics. The balance from low to high is spot on and the grind is amazing. Love it! I'll post some sound samples in a little while, after I get the Harvard up and running.
  14. gabasa
    gabasa Tele-Meister
    Toronto, ON
    Under the hood, four out of five tubes are NOS.
  15. gabasa
    gabasa Tele-Meister
    Toronto, ON
    The 1X10 5E3 was done a few days ago (see pic above) and the Harvard is now up and running. I'm really loving the sound of both amps and appreciating the Harvard because I haven't heard that sound since I sold my Clark Webster so many years ago. I can post a pic, but it looks exactly like the 5E3 above, minus the logo. Some thoughts:
    • I was initially shocked at how different the 5F10 and 5E3 sound. After an hour of playing it, I'm appreciating those differences.
    • The Harvard's cleaner, fixed bias tone is a breath of fresh air when you're used to playing colorful sounding amps like a tweed Champ or Deluxe. It's a WYSIWYG kind of tone in the prettiest way imaginable.
    • The Harvard is not a substitute for a 5E3, but a complementary amp for a different kind of sound. I love how the basses aren't pumped, while the lack of cathode-biased compression gives it a nice openness.
    • It's dead quiet in operation, almost freaky how there's no amp noise or hum while playing.
    • I used an audio taper pot for the volume, because it's what I could get at the time. The taper may actually be too slow and linear is the way to go as per the schematic.
    • The big sound of the Jupiter 10LA seems to work well with this circuit.
    Great initial impressions, it's a fantastic little amp. I can't wait for COVID to be a thing of the past so that I can try gigging with it!
    2L man likes this.
  16. David Barnett
    Are those Silmic II cathode bypass caps?
  17. gabasa
    gabasa Tele-Meister
    Toronto, ON
    Yes, nice catch, wow!
  18. gabasa
    gabasa Tele-Meister
    Toronto, ON
    Here's a pic of it. Done, minus the logo which is en route to my place.
    Junior Little likes this.
  19. David Barnett
    Assembled gut shots please!
    gabasa and Junior Little like this.
  20. jmp81sc
    jmp81sc Tele-Meister
    Orange County
    Fantastic looking amps! Now I'm thinking about Harvard's. I would also like to see the gut shots.
    gabasa likes this.
