Harvard (5F10)
Discussion in 'Shock Brother's DIY Amps' started by MeanGreenBlues, Jun 3, 2009.
  1. MeanGreenBlues
    MeanGreenBlues Tele-Meister
    North Texas
    Here's my layout (found it on someone else's photobucket :lol:):
    Well, the board, anyway. The grounding and tube socket wiring are as Mr Ridesglide said - just like the 5E3.
    The exception is the 6AT6/6AV6 in the first stage:
    The original 5F10 drawings have pin 4 straight to ground, but I wired it with one heater tap to pin 4 and one to pin 3.
  2. rlh5599
    rlh5599 TDPRI Member
    Sacramento CA
    Thanks MGB. That's some handy info!!
  3. MeanGreenBlues
    North Texas
    I'm so glad the ol' tech docs are still out there, too:
    6AV6-3AV6-12AV6
  4. RichardM
    RichardM Tele-Holic
    Ocean View near Bris Aust
    Thanks, I have that layout. [​IMG]
    I've done a 5E3, a 6G2, a AB763 Deluxe Reverb and a 50Watt Plexi lead.
    I have a 5C8 in the planning stages but I always wanted to try a 5F10.
    I nearly always make some changes to the standard layout, but if someone else has done the hard work. [​IMG]
    Thanks.
  5. MeanGreenBlues
    North Texas
    If that pic doesn't print actual size, I can get you the PDF that will so you can use it as a drilling template.
  6. RichardM
    RichardM Tele-Holic
    Not quite to size, but I'll re-draw it in AutoCAD.
    Thanks again.
  7. MeanGreenBlues
    North Texas
    I've got a PDF that I made in vector graphics that's to size. Just PM me and I can e-mail it to you.
  8. donfrantz
    donfrantz TDPRI Member
    MN
    Glad to see this thread revived. I've been delayed, but in the midst of a similar build with same layout.
  9. MeanGreenBlues
    North Texas
    I'm doing another one. :lol: The original one in this thread was sold a couple years ago.
    This new one's in Brown/Wheat:
    Got the chassis modifications done today:
  10. Mr Ridesglide
    Mr Ridesglide Friend of Leo's Silver Supporter
    Bloomington, MN
    Love Harvards
  11. MeanGreenBlues
    North Texas
    Here's a few more from today.
    Drilling and pressing terminals into the board:
    Tube sockets mounted:
    And now we wait...I have some components on the way! Hopefully just prior to New Year's I'll have the board populated and such.
    Thanks for following along. :D
  12. robrob
    United States
    Nice work and great photography.
  13. MeanGreenBlues
    North Texas
    Got some parts in the mail today:
  14. Viejo
    Viejo Tele-Afflicted Silver Supporter
    Central IL
    Beautiful work MGB. Is that one of Weber's stainless steel chassis or an older one? I ruined a good Greenlee punch on one of those stainless chassis, they are tough to drill or punch.
  15. MeanGreenBlues
    North Texas
    I'm thinking it is a steel one. Had some serious issues with my step-bit. I liked the older chassis better for sure.
  16. MeanGreenBlues
    North Texas
    A little more progress this holiday weekend.
    Nothing like some heater wiring:
    And a start on the power tubes:
    There are some more parts on order and should arrive next week. Will update y'all then!
  17. robrob
    United States
    That is a beautiful build. Solid core wire looks so much better than stranded.
  18. Emresound
    Emresound Tele-Meister
    Sydney
    I look forward to seeing all the awesome progression!
    Btw, for anyone who want to build this amp. The only PT I found that matches the correct specs of this build for export is the Hammond 270CAX.
    Check it out.
  19. tweedman2001
    tweedman2001 Tele-Afflicted
    Was North of There, Now Way Way South of There
    Damn nice but it's giving me gas.
  20. MeanGreenBlues
    North Texas
    I use Allen's Heyboer TP25 for mine - for those in the US or Canada:
    Upgrade Power Transformer for BF/SF Champ™, VibroChamp™, Bronco™, and Princeton™. 310V-0-310V @ 150ma, 6.3V at 4.5A, 5V at 2A. 50V bias tap, center-tapped heater winding and internal hum shield brought out to a lead for grounding. 2" by 2-1/2" mounting centers, 5.1lbs. Unit is approximately 1" taller than a stock transformer. Supports the use of both 6L6 and EL34 power tubes (with proper socket wiring). Now featuring M-6 grain oriented lamination steel for cooler operation.
    It is a little tall, but it drops right in the 5F2A chassis and there's clearance in the cab (but not much).
    Just waiting on a batch of parts from Antique Electronics now!
