Harmonic like noise on G-String
Discussion in 'Tele-Technical' started by TheBoss1983, Feb 12, 2016.
  1. TheBoss1983
    TheBoss1983 Tele-Meister
    Mönchengladbach, Germany
    Hey there,
    I heard a harmonic-like noise when I play the open g-string. It only appears when playing the open string.
    Just touching the string behind the nut between nut and tuners result in a clean and fine sounding string without that noise.
    Will a second string guide help? I will also try out to wind up a little more string around the tuner-shaft...
    What would you think?
  2. ricknbaker
    ricknbaker Tele-Afflicted
    Watford, UK
    Have you tried a new string? Does the nut slot look OK? Does the string sit in it properly?
  3. Saint Invective
    Saint Invective TDPRI Member
    Salt Lake City
    My first thought would be "sounds like the nut slot is slightly too big."
  4. TheBoss1983
    It seems the string fit the nut perfectly. How do I find out that a nut is slightly too big?
    Also guitartech told me a few minutes ago that a string guide will make the noise stop. He will find out if the nut is too big...
  5. ItchyFingers
    ItchyFingers Tele-Afflicted
    Ottawa Ontario Canada
    I would go with the extra string tree. It certainly won't hurt anything and the price is right.
  6. TheBoss1983
    Before I'll forget: I hear that noise fade out after touching or muting the string.
  7. telex76
    telex76 Doctor of Teleocity Ad Free Member
    Fort Worth,Tx.
    String needs to be wound down further on the tuning peg.
  8. TheBoss1983
    I already tried this today. It wasn't the solution...
  9. Saint Invective
    Salt Lake City
    If it were bad enough to cause audible harmonics or sitar-like sounds, you'd probably be able to feel it move in the slot just by using your finger to wiggle it from side to side.
    If it looks and feels tight in there, then it's probably something else.
  10. brogh
    brogh Assistant Admin Staff Member
    italy
    altough the title made come to my mind something really different and nothing about guitars .. :D
    I think another string tree might help, i had that once but there was a nut problem, it's not your case you say. so the string tree should help.
    Cheers
  11. LutherBurger
    LutherBurger Friend of Leo's
    NYC
    It's probably a bad nut slot, but a second string tree might add sufficient downward pull to stop the noise.
    A temporary solution might be to wrap a rubber band or hair tie around the headstock and strings behind the nut.
  12. fender4life
    fender4life Friend of Leo's
    los angeles
    Just take a piece of scotch tape about 1/4" square and bend it over the string. That will deaden it and it's clear so you don't even see it. Quick simple fix.
  13. TheBoss1983
    I tried out that but it doesn't feel like it's moving in there... Hmmm.
    I was told, the problem could also be the angle of the "nut-cut".
    I hope it's done with the second tree. :neutral:
  14. surfoverb
    surfoverb Doctor of Teleocity
    Virginia
    tie a piece of rubber band around the G string behind the nut.
    yes a new string tree will work the same but thats not free
    and your tech needs money so he wont tell you about that.
    a rubber band will work for years. Its temporary only cuz rubber doesnt last forever.
  15. Sakie8015
    Sakie8015 TDPRI Member
    SoCal
    This is a common thing. Scott Grove has a whole YouTube video about it. You can even stick a piece of foam or something under the string. Another string tree will work, but like someone else said, it's not free, and on top of that its just one more hole that you'll need to drill into your guitar.
  16. antennahead
    antennahead Tele-Meister
    Charleston, SC
    Sympathetic resonance. I had it on my 52 RI, added a second string tree and problem solved.
  17. bo
    bo Poster Extraordinaire
    Arlington, VA
    I've had that happen a few times over the years. Yes, it's almost certainly a bad nut slot. I use a small piece of kitchen sponge underneath the string behind the nut.
  18. Novatuc
    Novatuc Tele-Meister
    I have seen a guitar with a piece of leather shoe lace woven in and out of the strings behind the nut. It killed all harmonics and was something so simple.
  19. cousinpaul
    cousinpaul Friend of Leo's
    Nashville TN
    Before you add a second string tree, push down on the string behind the nut and see if the noise stops. If not, the string may have worn it's way through the nut material to the point where the nut needs to be shimmed or replaced. It's a pretty common problem, especially with plastic nuts.
  20. cousinpaul
    Nashville TN
    Sorry, double post...
