Bought one of these ,and it arrived in a matter of a few days.
I had ideas about using just the body for a Tele/Esquire partscaster.
Nope , the Fender neck is a very sloppy fit in this body from side to side , an ugly gap will be the result. The HB neck is also quite a bit thicker at the heel , so the Fender neck would at least require a rather thick shim to line the strings up in so-so fashion over the saddles.
So , Im stuck with the HB neck. Its a Roasted Maple style , maple cap neck. Frets are very rough feeling , but Im sure it will benefit from a fret level anyway , so that will be done with after the level/polish.
2 string trees , both not tightened , and much too 70´s for my taste. Holes allready filled , and a round string tree fitted in the 50s placement , and only on e and b strings.
Nut was not too far from what I prefer , only spent minutes cutting the slots a bit deeper. Appears to be decent material , not too soft , so it stays.
Pickguard , not the usual shape , but if the front pu get moved a bit , I think a Fender spec guard could be fitted.
Switch , is the cheap asian type , will have to go , pots and jack as well. Jack plate , is the typical cheap one. Either a Gibson LP plate , or an Electrosocket ( old screw holes will show )
Pickups are surprisingly good , although rather low output...
Oh yeah , tuners ....ehhhh......no , new vintage tuners will be used.
Weighs 7 pounds even.
I got carried away , the color tricked me into getting one.
Its a typical cheap guitar , neck is maybe slightly better than what could have been , but not much.
I will fix it up , and keep it. Maybe use some weird wiring mods for fun , but when Im done , the neck will have seen hours of work.
The body and MAYBE the pickups will also stay , the rest will be changed out.
