Harley Benton - Guitar DSP Monitor with built in Cab Simulations
Discussion in 'Modeling Amps, Plugins and Apps' started by Thin white duke, Mar 26, 2020.
  1. Thin white duke
    Thin white duke Tele-Afflicted
    italy
    Is this going to be the next step or there are others from different brands ?
    tah1962 likes this.
  2. Shuster
    Shuster Poster Extraordinaire
    Bulverde Tx.
    Plenty of others! I'm running a pair of Headrush 108's and they are more than I need, but they sound sweet with the Gigboard and AA12;) Though this would be good if you don't have IR's loaded in the pedal!
    tah1962 likes this.
  3. Thin white duke
    italy
    Does the Headrush 108 have cab. simulations built in ?
  4. Shuster
    Bulverde Tx.
    Na, that's where both the Gigboard and Atomic are loaded with IR's, so no need. But for a pedal that has no cab sims, that HB frfr would be the answer!
  5. Thin white duke
    italy
    A ok, that's what i tought.
    Yes that's what i was saying, with this cab you don't need an I.R. pedal for example, i was wondering if ther are others because i don't think i've seen something similar....
  6. Shuster
    Bulverde Tx.
    I haven't seen anything with screen like that, which is cool if it stays working! I'd check to see if you can load IR's into that speaker, that would really make that a good buy!
  7. Thin white duke
    italy
    I don't think you can do that, it would be great....
  8. chris m.
    Santa Barbara, California
    I know IRs are all the rage, but in theory couldn't you achieve the same result with some careful manual EQ adjustments?
  9. Thin white duke
    italy
    I don't think so, i don't have an I.R. pedal but a friend gave me his Mooer Radar for a concert and the result with the Joyo A.S. before was very very good, when i was trying it the days before the show i tried to see if i could get a similar sound with an eq pedal but it wasn't the same, maybe somebody better than me could do that...:):)
    Shuster likes this.
  10. Shuster
    Bulverde Tx.
    95% of the IR's I've uploaded were free, they're everywhere!
  11. codamedia
    Western Canada
    This is just an option to the Line 6 Power Cab.... although at less than half the price of the cheapest Power Cab ;)
    • The regular Power Cab can be set to FLAT so the modeler does all the work (ie: cab simulation), or it can be set to a variety of different speakers/cabinets...
    • The Power Cab Plus has all that, plus you can load your own IR's, plus MIDI so you can have a modeler or amp change the cabinets on the fly.
    • They also have a 2x12 version of the Power Cab Plus
    Laney also makes something similar.... but without a screen and only three modes (flat, combo, stack)
  12. Thin white duke
    italy
    Ah ok, that's what i was asking, if there is already something similar, the Line 6 seems to be the answer, much more expensive though....:):):)
    codamedia likes this.
  13. Hari Seldon
    Hari Seldon Tele-Meister
    Germany
    You'd need something like a 1000 band eq and know how to set it.
    Thin white duke likes this.
