Hand wired versus SMP!
Discussion in 'The Stomp Box' started by thecornman, Oct 3, 2014.
  1. thecornman
    thecornman Tele-Meister
    Saskatoon, Canada
    In what way is a hand wired pedal going to sound better or be more reliable then a SMP pedal using the same parts?
  2. waparker4
    Philadelphia, PA
    Probably sound the same except for discontinued parts that aren't available as SMD. Might include components that are more expensive whereas an SMD mass produced pedal might be more likely to sub in less expensive versions of nearly the same thing. Those choices in my opinion would have an unclear effect on overall sound. Maybe good, maybe same, maybe worse. It's in the ear of the beholder anyway.
    Might be more reliable in that the jacks and switch will be mounted to the enclosure and not to the PCB. Will be more repairable, although the repair may cost the same as a brand new replacement of the SMD mass produced version.
  3. chrisgblues
    chrisgblues Tele-Afflicted
    Halifax
    Both methods will sound the same. Even the notoriously picky maker of the Klon (finnegan) went with SMD in the end and claims the sound is identical.
    As far as reliability, both methods can be equally reliable when done correctly. You could argue that hand assembled circuits are easier to modify and repair if necessary, that's probably the only advantage of one vs the other.
    JMHO.
  4. String Tree
    String Tree Doctor of Teleocity Ad Free Member
    Up North
    IF you are in a bind and have to repair it fast for a show, that is a huge advantage.
  5. Greg.Coal
    Greg.Coal Tele-Afflicted Silver Supporter
    Colorado
    If you listen with your eyes - not uncommon - you might hear better sounds from the technology that cost more and has a name that has words in it like "swollen", "puss", "mad", "hand-painted/hand-wired", etc ....
    ... but hear bad things from cases with "bob-, bill-, or danelectro" on the top.
  6. surfoverb
    surfoverb Doctor of Teleocity
    Virginia
    it will sound better when you you go to sell it
    "hand wired, gooped, mojo out the wazoo!"
    sounds better than
    "mass produced"
  7. 1300 E Valencia
    Fullerton CA
    Because the internet says so.
  8. tube.tone
    tube.tone Tele-Meister
    Northeast
    Serviceability is the biggest argument. Components and connections are bigger and accessible what makes countless desoldering and soldering possible and easy.
    What really bothers me on electronics is the disposable nature of "most things" that are mass produced. I tend to keep stuff for a long time so longevity and serviceability are a plus.
    As an exemple, I own a solid state stereo system built in 1974, I have just replaced every single electrolitic capacitors, serviced all pots and it's good to go for another 40 years.
    Yes, it sounds better than anything newly produced I could afford. :)
