(Half) out of phase questions
Discussion in 'Tele-Technical' started by Mr. E, Jan 23, 2012.
  1. Mr. E
    Mr. E Tele-Holic
    I'm currently looking for mods on a telecaster I'm redoing. I would want something more "versatile" so I'm using a 4 way switch with a P90 in the neck with a Cavalier Lion pickup at the bridge. Along with that I want to add a push-pull pot for out of phase switching. I've been hearing alot about the half out of phase option too. I'm curious about these two. Especially the half out of phase. Does anyone have clips or know where I could find more info on this?
  2. Phostenix
    Phostenix Tele-Afflicted
    Phoenix, AZ
    Teleterr likes this.
  3. Guitartom_ca
    Guitartom_ca Tele-Holic
    This wiring HOop is in the following youtube clip about 2:50 into the clip.
    moosie and trouserpress like this.
  4. boris bubbanov
    New Orleans, LA + in the
    Excellent demo, Tom.
    I like the way the output stays up when you pull the knob. You seem to have just the right amount of out of phase; not too much.
  5. rolling56
    rolling56 Friend of Leo's Silver Supporter
    Mangling notes since '81 in SW Misery
    Hi Tom, nice playing. Do you have a link to the wiring schematic you used? I already looked at Phostenix site but didn't see it.
  6. Phostenix
    Phoenix, AZ
    I've got a bunch of diagrams that include HOoP. What exactly are you looking for?
  7. Phostenix
    Phoenix, AZ
  8. rolling56
    The one that Guitartom_ca is using. 3 way with push pull pot HOop. I think that is what he is using?
    I see the 5 way HOop on your site but not for a 3 way.
  9. Phostenix
    Phoenix, AZ
  10. Phostenix
    Phoenix, AZ
    You would wire the push-pull pot like the toggle switch diagram I linked to. If I have time, I'll make a version for a push-pull pot.
    The resistor is optional if you are just using a toggle or push-pull pot. I find the resistor more useful when you can also put a resistor in series with the other pickup, as well - like you can with a 5-way Super Switch setup.
  11. rolling56
    sorry off topic to the OP :oops:
    No hurry at all but would like it for a 3 way switch (bridge,bridge with neck,neck [standard tele single coil pickups]) with push pull pot please and thank you in advance :D
  12. Phostenix
    Phoenix, AZ
  13. Phostenix
    Phoenix, AZ
    I've found it to be common that the pickups half out-of-phase are actually a little louder than the normal pickups in parallel.
  14. rolling56
  15. Phostenix
    Phoenix, AZ
    This video of the Jerry Donahue Omniac also has a quick sample of the HOoP position (Position 2) at :55
    http://www.youtube.com/watch?v=QjaHboa_qWU
  16. Phostenix
    Phoenix, AZ
    It would be used with the standard Tele 3-way setup. The Red wire in the drawing goes to the pickup selector switch where the Neck pup White wire normally goes.
  17. rolling56
    ah k got it thank you :cool:
  18. Phostenix
    Phoenix, AZ
  19. jefrs
    jefrs Doctor of Teleocity
    Newbury, England
    The half out of phase is one of the Baja positions - a 10nF (103) cap is placed in series with the neck pickup when it is in parallel but out of phase with the bridge pickup. The cap is not in place when the pickups are in series out of phase, but it is possible to re-wire the 4-pole S-1 to do this. This is not the tone cap, that is a 47nF (473).
  20. Phostenix
    Phoenix, AZ
    trouserpress likes this.
