GZ34 in a Weber Tweed deluxe
Discussion in 'Amp Central Station' started by Nick Fanis, Jul 2, 2020.
  1. Nick Fanis
    Athens-GREECE
    I have an old (about 15 years) tweed deluxe (Wever kit) ,it has a large transformer that can also accept 6L6 .
    I am currently running 6V6s and a 5Y3 rectifier but yesterday the 5Y3 died and in pinch I swaped it for a GZ34.
    The amp sounds much cleaner ,tighter and "musical" to my ears and I want to keep it this way. It is also less noisy.
    Is there any way the GZ34 will cause some damage to the amp,tranny and the ,very expensive,RCA blackplates I am using at the moment?
  2. Kevin Wolfe
    Kevin Wolfe Tele-Meister
    Lakeland FL
    I would advise checking the bias. Specifically the plate dissipation. The GZ34 will supply significantly higher B+ voltage. If it’s not red plating, and sounds good, you’re probably safe. Personally, I like to know. Especially with those precious power tubes.
    dan40 likes this.
  3. dan40
    dan40 Tele-Afflicted
    Richmond Va
    Yep...definitely check the bias. With the higher plate voltage brought about from using the GZ34 the tubes are likely running a bit hotter.
