muchxs
Whole front part of this (zombie) thread is about Princeton Reverbs. Fender changed from the 022772 PT to the 01--- whatever. A few early units for the 125P1B but they're mostly the 022772 "Champ" transformer. They made the change in 1970. Princeton Reverbs up to 1970 usually have the 022772 unless it mellted and was changed. The quick way to melt a 022772 is to run a 5U4G rectifier. It will still take a while. The transformer will run barbecue hot.
Aftermarket "022772" transformers are more or less faithful to the specifications of the original. We want the ones that are less faithful top the original design. We want 5V / 3A and high voltage as low as we can get it. Stock is around 330v-0-330v. There are aftermarket versions intended to run EL84 tubes. Start low and jack the high voltage with a GZ34. You amp will thank you.
See... 6V6 tubes were designed to operate on 300v max. 6V6GTA tubes will withstand much more. Still, they sound stressed to me up and over 400v. Maybe it's just that I know I'm cutting the life expectancy of my tubes in half.
On to the Deluxe Reverb. '60s versions use Fender's AB763 circuit. Every other AB763 amp uses 6L6 tubes. It's as if Fender designed the '60s line, ran out of time with the sale to CBS and found themselves very light on "6V6" amps.
Stock Deluxe Reverb transformers will likely run 5U4G rectifiers or GZ34s. I really don't like how high the high voltage goes. Never have. Good old RCA 6V6GTA tubes as used in 1965 will live. I wouldn't trust EH or Tung-Sol reissues in there. It's not like we have a lot of good choices here...
Actually, we do. Go off the charts. The tube charts that is. Use a 5V4 rectifier. It drops voltage more like a 5U4G but it has a 2 amp filament like a GZ34.
I have a sleeve of Sylvania "GZ34s" that are likely 5V4s. They look just like 'em.
I never liked the high voltage situation in Deluxe Reverbs so I fixed it. I went in with an associate. We had Classictone wind a bunch of Deluxe Reverb transformers with tapped high voltage secondaries. We had 'em wound with 2 amp filament windings. The idea was to keep the transformer as light as we could. If I had to do it over I might pay the weight penalty and use a 3 amp filament. I know better than to use a 5U4G with that transformer. Still, it's a question that comes up all the time.
