Gulity feeling after I added string tree to my 52 Re-issue.
Discussion in 'Telecaster Discussion Forum' started by Joely, Jun 4, 2011.
  1. 92Standard
    92Standard Tele-Meister
    Huntersville North Carolina
    As long as it plays great and sounds good...right?
  2. Joely
    Joely Tele-Meister
    Hertford UK
    Thanks for the input fellas!!
    Did my first pub gig since adding the tree and it was a great having not to worry about the old over tone G string...... The only G string i had to worry about was the dunken fat bird who fell over dancing and we all got a glimpse of tomorrows washing!!!
  3. DOGMA Dunn
    DOGMA Dunn Friend of Leo's
    Reno
    Does that extra tree put more downward tension on the string to tighten up the snap/twang in sound? How did you like the results?
  4. Joely
    Joely Tele-Meister
    Hertford UK
    There is a bit more tension but not stiff tight. The sound did sound much tighter only because the ghost G overtone had gone. It was just to change the angle really.
    When my guitar man put the tree on he used a 5mm spacer before the spring tree so the down pull isnt too great. I havent noticed an increase in snap as such but that perhaps would change if the tree was flush with the neck creating much more tension ...it also may cause a few more strng breaks..... I may be totally wrong and be talkingout of my bottom!! lol....discuss!!
  5. DOGMA Dunn
    Reno
    Thanks Joely, I think you are right. I had the same issue with my strat, which has similar string tree. And adding another did help tighten it up. Now that you mention it, the spacer can be adjusted to taste for tension. More options for my guitars. Thanks.
  6. szechuanking
    szechuanking Tele-Holic
    new jersey
    you do know thats an original not a reissue right? totally worthless...
  7. garyd5158
    garyd5158 Tele-Afflicted
    Connecticut
    Maybe you're starting the new trend. Looks good to me and if it plays better and its your keeper guitar, nothing to feel guilty about.
  8. Joely
    Joely Tele-Meister
    Hertford UK
    Szechuanking.......dont get that.
  9. Joely
    Joely Tele-Meister
    Hertford UK
    I have to add that is not my guitat in the photo.... It from another thread but mine is exact to this (or that in the above photo)
  10. Mark N
    Mark N Tele-Afflicted
    Woodstock, NB, Canada
    Hey Joel....that's my tele in the pic fellas...the second string tree was there when I got the guitar back in 97....I see no pro's or cons to the second tree, I guess it has some kind of purpose...I have teles with just one tree and they are fine. I wouldn't worry about it Joel, if you add/added the extra one it should be fine. Play that tele with authority man! :)
  11. garrett
    garrett Tele-Afflicted
    Just south of Tampa Bay
    After years of torture, I added a second tree to my Deluxe Nashville. I went with a modern tree, though.
    Much happier now.
  12. Joely
    Joely Tele-Meister
    Hertford UK
    excellent news.....daft i know but i dont feel as bad now..... cheers garrett...
  13. garrett
    Yeah, no worries. I put off doing it for a long time. I used to stick a pick in the strings. Then one day, in a fit of inspiration / frustration, I got the drill out and coldly went about the business.
    I felt a bit of remorse for making extra holes in the headstock, but I now have a more consistent break angle across all strings and no more annoying ringing harmonic.
    And no more putting a gazillion wraps around the G post...
  14. bo
    bo Poster Extraordinaire Silver Supporter
    Arlington, VA
    I'd've used a small piece of kitchen sponge under the strings, but another string tree will do the job too.
  15. Jimmy Dean
    Jimmy Dean Friend of Leo's
    Portland, OR, houseboat
    I wouldn't sweat it now. If you remove it, you will have a hole to fill & re-finish.
  16. strat_tone
    strat_tone Banned
    For the reference of others considering it, you can just put a strip of paper over under over the strings. It should stop any overtones coming from the other side of the nut. I think there's a picture of Roy Buchanan's tele floating around with that. Just something to consider.
    Also I would think it would result in a slightly higher higher tension in those two strings, which I know many do a lot of bending on. Just something to consider.
  17. garrett
    I tried using a little strip of felt. Worked okay, but I hated the way it looked. I wove a pick in the strings for a long time, but that was a bit annoying and didn't look right either. A string tree is definitely the more polished, "belongs there" solution.
    I remember back when I used heavier strings (10's or 11's), removing the second tree from my Strat was a revelation in playability. But now that I use 9's it doesn't seem to make any difference on bending the G. I actually recently put the second tree back on my Strat, to shut up its overtones.
  18. Joely
    Joely Tele-Meister
    Hertford UK
    seems we have a few closet tree stringers!!! lol
  19. Joely
    Joely Tele-Meister
    Hertford UK
    string tree and proud!!
