Guitarbuild UK Telemaster guard
Discussion in 'Tele Home Depot' started by PeterUK, Mar 17, 2020.
  1. PeterUK
    PeterUK Poster Extraordinaire Silver Supporter
    Nottingham, UK
    Has anyone purchased a Guitarbuild Telemaster pickguard?
    I want to have a clear pickguard made and need a template.
    I've approached Guitarbuild and they replied:
    If you have one will you make me a template please; a simple A4 tracing would be great.
    Thanks in advance. :)
    LeftFinger likes this.
  2. BorderRadio
    Phoenix, AZ
    I have a MIJ Offset Tele, but I suspect it’s different enough to be no use for you. Let me know if you’re interested, after you hold out for what you need :)
    PeterUK likes this.
  3. netgear69
    netgear69 Tele-Afflicted
    england
    Print
    select/ actual size /poster
    BorderRadio, PeterUK and LeftFinger like this.
  4. LeftFinger
    LeftFinger Friend of Leo's
    Saskatchewan
    Thankyou I needed that :lol:
  5. PeterUK
    Nottingham, UK
    Awesome!
    I've got the MJT PDF and it's slightly different.
    :D Peter
  6. PeterUK
    Nottingham, UK
    I found an online PDF for the MJT and it's not quite the same. :)
    BorderRadio likes this.
  7. tweeet
    tweeet Tele-Holic
    england
    I've got an mdf template of a Tele pickguard if you want it...I don't build anymore (long long story) ...it's pretty accurate and could come in useful ?
    PeterUK likes this.
  8. PeterUK
    Nottingham, UK
    That could prove useful. Let's agree a deal in PMs?
    Thank you. :)
  9. PeterUK
    Nottingham, UK
    @netgear69 Thank you for the template.
    It's a little too big for the Guitarbuild TM.
    FYI, the scale of the print out is spot on as a controlplate sits in the space perfectly.
    The MJT is a better fit but doesn't hit the controlplate area correctly.
    Between the two I can create a really close template and then have Jack's Instruments produce one.
    I'm tempted to order one from Guitarbuild but it's a £24 investment I won't get a return on.
    I appreciate the help and support. :)
  10. netgear69
    england
    Cool Pete just amend the sizes to fit, make your own £24 seems a bit much you can buy a couple of sheets of perspex on ebay for half that price
    although it is a pain to cut if you are making your own just put a layer of masking tape on it it stops it melting on the blade
    PeterUK likes this.
  11. Chordophonic
    Chordophonic Tele-Meister
    Isle of Wight UK
    I think I still have one Pete, Ill have a look later...
    PeterUK likes this.
  12. PeterUK
    Nottingham, UK
    A quick update for those looking for a Guitarbuild pickguard but want something other than the limited selection that Guitarbuild offer.
    Get in touch with:
    https://jacksinstrumentservices.com/
    They have created a CNC model of the Guitarbuild pickguard and can create a pickguard from the wide range of materials they stock.
    A big thanks to @Chordophonic for loaning me his. Jack's Instruments Supplies have made me a perfect copy in clear acrylic but for now I've left the protective coating on.
    :) Peter
    RomanS and Chordophonic like this.
