stxrus
Sometimes the simplest of solutions are the hardest to find
When I bought my motorbike, it had an ugly plastik sticker with informations on the top of the tank.What a stupid place for it ! So I tried to remove it but could not remove it in one piece.It only went off in little flakes, leaving a sticky surface.Yep. I’ve bought some used guitars and tried to remove that pickguard film on a ten year old guitar. What a freakin nightmare. And no, it won’t help your resale value. Peel that crap off, people!
I have a digital 8 trac recorder for now maybe 10 years.Also recently discovered that there was a plastic film on the displayI can't tell you how many times I have done that. Once I thought my microwave control panel was getting foggy and needed replaced so I called a repair guy, he comes out and peels the film off the control panel. $85
How embarrassing!
Whatever you do, keep it to yourself!!!
[My partner discovered last week that the mobile phone she's had since 2019 still had the plastic protective cover on the screen. She thought it was scratched but it was just a mark on the plastic.]
Here's some guitar porn for you. Enjoy.This will never happen to me. Stickers and film go as soon as I know it's a keeper. Kind of a problem I have.
In fact, I've seen some recent posts with film still on the pickguard or pickups and really, really want to arrive at the poster's homes to remove it.
YupSCORE!
Don't beat yourself up for this because even your tech missed it. Sometimes we cannot see the forest because of all those trees blocking our view.
However, I wouldn't tell anyone about this
I've done it. We've all done it.
I feel your pain. Totally. It's odd that it would have hung on the shelf for so many years, but, such is the vagaries of us musicians. A few years ago, I stumbled across what I figured was my dream Strat. It was the neck that had me take it off the wall at a local store. I didn't need to feel it to know that it was the one. And sure enough, it was. Why, I asked, had it hung on the wall for three years? It was a Custom Shop Strat, and they had marked it down considerably??? Bewildered, I bought it anyways, and the action was horrid. That is likely the number one reason it never sold. I took it to a local pro shop, paid them $150 or what ever it was, and it is my desert island guitar. I was not able to sort it out myself, in spite of having set up my own guitars for over thirty years, but the pros intervention saved the day. There were no stickers in the way, but sometimes we need the expertise of an outsider.So, a few weeks ago I picked up a new guitar - it is a NOS 2011 Schecter Solo Six LTD Goldtop. It played fantastically in the store, sounded gorgeous, but with one issue - the high e string choked out badly when bending. Their resident guitar tech was on vacation, otherwise they said they'd have done a setup on the spot. The action of the guitar was otherwise fantastic, everything looked right, it played like butter apart from this issue. I bought it anyway as I do all my own setups, and figured that it needed a truss rod tweak and set up, as it had hung on a shelf for 11 years.
I got the guitar home and didn't have time to touch it for 2 weeks but finally got it on the work bench 2 days ago... which is where the fun started.
Here is the repair log of shame:
- I took off the old strings assuming that they were 10's. Checked the neck with the strings off to get it flat. Checked the relief with the new strings on and adjusted to my 'normal' amount. ~0.010". Realised that there had been 9's on there, but no worries. The choking still happened. Ok, moving on.
- I checked the string height, it was ok compared to my other guitars, but I raised the bridge a fair amount on the high e side. Still choking out. Hmm. I raised the bridge higher, still no luck. So I went hunting for high frets and found a *very* marginal one at the 17th fret, but really small. Dealt with this. Choking still happening. I was now officially thinking it was weird.
- Figured I'd redo the setup but with 9.5 strings as I preferred how it felt with a lighter gauge, and work backwards rechecking everything to find the issue. Everything looked fine, and although the action was now a bit too high, it played really nicely at the cowboy chord end... but still choked out. Argh.
- Checked the nut height, all fine, checked the slot depth, all fine.
At this point I was exasperated and could see no cause for the issue and was also thoroughly pissed, so figured I'd go to my tech.
This morning I took it to my local store/luthier, who does all my repairs and hard setups, and explained the issue. They looked at the relief, string height (too high for me, but they said that it was within their setup boundaries), nut etc - they confirmed everything looked perfect. We scratched our heads for about 10 mins, checked for neck deviations, bad frets, anything that could explain it... We were all out of ideas.
Then they commented that it was amazing that a 2011 NOS guitar even still had the protective stickers on the pickups... ARGH. BINGO.
Turns out that the protective sticker on the neck pickup was beginning to be non-sticky and peel up... and was touching the string choking it out. I'd not noticed at all, and seemingly it was going back to the same place each time the strings were changed, blocking the path. We removed the sticker and everything was instantly fixed.
I wanted the ground to open up and swallow me. The shame of it! ><
Luckily everyone had a really good laugh, and not just at my expense (trying to work out the service charge for peeling off a sticker!), but wow, I'd never ever have thought that the sticker would have been the culprit... it'll teach me for leaving them on and trying to keep the guitar 'new'!
I don't think I'll ever live this one down in the store!!![]()
Especially when you know enough things like relief, checking for high frets, etc. Been there and done than, more than once. Best tool in the box is Occam's RazorSometimes the simplest of solutions are the hardest to find
That also could have happened to me ....that's ok, I almost rewired an entire pedal board on the fly because the FOH wasn't getting a signal. There I am, on stage frustrated that no sound is coming out. I am popping and replacing patch cables on my board, changing out power leads and anything else I can think of. Sound guy comes up on stage to help. He looks at me and says, "you are gonna kill me."
I give him the "what?" look and he bends down and picks up the end of my guitar cable and plugs it into the guitar. "THUMP" through the system...
I almost cried.
I did just this the other day after rewiring a pot (I posted about it being a weird wiring). Once I returned it to normal, I couldn't get a sound out of the guitar at all. Was about to get inside it again when I saw I hadn't plugged it in. (Oye Vey!)After thirty years of playing I still catch myself not plugged in. I’ve learned to check there first.![]()
