marc2211
So, a few weeks ago I picked up a new guitar - it is a NOS 2011 Schecter Solo Six LTD Goldtop. It played fantastically in the store, sounded gorgeous, but with one issue - the high e string choked out badly when bending. Their resident guitar tech was on vacation, otherwise they said they'd have done a setup on the spot. The action of the guitar was otherwise fantastic, everything looked right, it played like butter apart from this issue. I bought it anyway as I do all my own setups, and figured that it needed a truss rod tweak and set up, as it had hung on a shelf for 11 years.
I got the guitar home and didn't have time to touch it for 2 weeks but finally got it on the work bench 2 days ago... which is where the fun started.
Here is the repair log of shame:
- I took off the old strings assuming that they were 10's. Checked the neck with the strings off to get it flat. Checked the relief with the new strings on and adjusted to my 'normal' amount. ~0.010". Realised that there had been 9's on there, but no worries. The choking still happened. Ok, moving on.
- I checked the string height, it was ok compared to my other guitars, but I raised the bridge a fair amount on the high e side. Still choking out. Hmm. I raised the bridge higher, still no luck. So I went hunting for high frets and found a *very* marginal one at the 17th fret, but really small. Dealt with this. Choking still happening. I was now officially thinking it was weird.
- Figured I'd redo the setup but with 9.5 strings as I preferred how it felt with a lighter gauge, and work backwards rechecking everything to find the issue. Everything looked fine, and although the action was now a bit too high, it played really nicely at the cowboy chord end... but still choked out. Argh.
- Checked the nut height, all fine, checked the slot depth, all fine.
At this point I was exasperated and could see no cause for the issue and was also thoroughly pissed, so figured I'd go to my tech.
This morning I took it to my local store/luthier, who does all my repairs and hard setups, and explained the issue. They looked at the relief, string height (too high for me, but they said that it was within their setup boundaries), nut etc - they confirmed everything looked perfect. We scratched our heads for about 10 mins, checked for neck deviations, bad frets, anything that could explain it... We were all out of ideas.
Then they commented that it was amazing that a 2011 NOS guitar even still had the protective stickers on the pickups... ARGH. BINGO.
Turns out that the protective sticker on the neck pickup was beginning to be non-sticky and peel up... and was touching the string choking it out. I'd not noticed at all, and seemingly it was going back to the same place each time the strings were changed, blocking the path. We removed the sticker and everything was instantly fixed.
I wanted the ground to open up and swallow me. The shame of it! ><
Luckily everyone had a really good laugh, and not just at my expense (trying to work out the service charge for peeling off a sticker!), but wow, I'd never ever have thought that the sticker would have been the culprit... it'll teach me for leaving them on and trying to keep the guitar 'new'!
I don't think I'll ever live this one down in the store!!
