Guitar Novices's 2012 Challenge Build Thread -- COMPLETED
Discussion in '2012 TDPRI Tele Build Challenge' started by Guitar novice, Mar 13, 2012.
  1. Guitar novice
    Guitar novice Tele-Afflicted
    Perth
    I'm in
    Good luck all. May our wood be straight and errors be few.
    Cheers
  2. crazydave911
    East Tennessee
    You'll be fine mate :)
    Welcome and good luck! :D
    Dave
  3. RogerC
    RogerC Poster Extraordinaire
    Oklamerica
    Right back atcha! :D
    Good luck!
  4. Guitar novice
    Perth
    Thanks guys
    My backup plan was to use prev year challenges as a guide but it seems tdpri thought of that already.
    A lot of entires this year. Plenty to compare notes to.
  5. RogerC
    Oklamerica
    I kinda had the same idea, but oh well. Onward and upward!
  6. Guitar novice
    Perth
    Away we go.
    First the wood shot.
    I got this timber from a local timber guy. It's Queensland Maple. Thin pieces are not great quality and they will form the back of the guitar. The thicker pieces will be the front.
    The neck has some nice figuring but not what the US guys are used to. I fall into the disqualified beginner category. I'm new but previously had a crack at cutting a body. First thing I notice of this timber is that it is really light compared to the American Oak.
    Cheers
  7. Guitar novice
    Perth
    Closer shot of Front body[​IMG]
    Closer shot of neck - got 2 blanks for just in case
    Fingerboards - got them for a luthier down south. They are ebony and rosewood. I think I will choose the shorter one for this project
  8. Guitar novice
    Perth
    The Plan
    Plan A was to do a Tele thin line using some ron kirn templates.
    Plan B
    My niece who is 6 years of age is starting to play guitar. When she heard that I was going to make a guitar and suggested that I make her one at some stage her eyes lit up. The rest is history. Plan B was formed. Her first lesson is in 6 weeks time so i'm going to need to get to it.
    3/4 size guitar using the design that JKingma had used (I think its a terry downs derivative). 2 Piece neck. Pickups will likely be a Squire CVC cannibalisation. I have ordered pickup wire and other gear to wind my own so will try to diy if I get time.
    It's not an ambitious build but it's all new so I thought I wouldn't overreach this time.
    Cheers
  9. paulmarr
    paulmarr Tele-Holic
    Adelaide, Australia
    Aussie Aussie Aussie - you have my attention! :cool:
  10. Guitar novice
    Perth
    Progress last few days.
    With the help of some new tools...
    Ive started on templates.
    First went to office works and printed to scale the design. I then sprayed some adhesive on some thin mdf and laid the template down. I sprayed the adhesive on top of the paper as I heard that helps with reducing ripping when you work the edges.
    Next band saw a rough outline. I found it tricky to get round the curves so I was wondering if a smaller width blade would be better. Ive bought a couple of spare blades in case that was needed.
    Finally I took it to the spindle sander. Ive heard people rave about the ROSS. I can't get that ridgid Ross here but the sander is amazing. Gotta be up there in the tools to get.
  11. Guitar novice
    Perth
    The last photo shows that I need to sand more to the line. I'm still deciding if I use the spindle sander, hand sanding or rout the edges like Colt does.
    Hmmm... In the meantime I need to glue up the blanks so I can finalise the templates tomorrow.
    Cheers
  12. Guitar novice
    Perth
    Cheers Paul. Lets see what a mess I can make :D
  13. jkingma
    46°03'31.2"N 79°44'28.3"W
    Admin Post
    You are correct.
    Good luck with your build... I can't wait to see it.
    Oh and BTW... just because its a smaller guitar does not mean its not an ambitious build. Its just as much work as any other build.
  14. RogerC
    Oklamerica
    I like the plan...a lot. Regardless if you win anything, I'm sure you'll feel like you won the world when you hand that guitar to your niece
  15. Guitar novice
    Perth
    I just sent her pictures of the templates. She's so excited it's infectious.
    Apparently she's talking about starting a band. Never touched an instrument. Gotta lovev6 year olds.
  16. Guitar novice
    Perth
    More progress tonight.
    I have jointed up the blanks using router. Will upload pictures tomorrow as I'm stuffed now.
    Cheers
  17. dilbone
    dilbone Tele-Afflicted
    Bowling Green, Ohio
    I'll be watching this one for sure...I've toyed with the idea of building my 10 year old girl a guitar...she would love it but I'm not sure how serious she would ever be about learning to play.
  18. Guitar novice
    Perth
    I'm in same boat dilbone. Chances are my niece won't keep the interest in guitars. But. If she does and remembers the first guitar she got was handmade by me then that's just priceless.
    Cheers
  19. Guitar novice
    Perth
    Update.
    I've finished the thin templates. The sander left a few grooves so I tidied it up with some hand sanding. Hopefully later tday I will transfer to a 3/4 inch template. No photos of the hand sanding.
    I have joined the two body blanks. My method is basically get my stew Mac fret level bar and tape it to top of blank. Then on router table I trim the edges. I read somewhere n here is a trick. One side you rout with top facing up. The otherside you rout with top facing down. The idea is if the router bit is slightly off angle the 2 pieces will still join.
    Another trick I learned is that the tape is quite sticky but if you apply uneven pressure then the face won't be straight. I had to redo one side using more even pressure.
    Photos...
  20. Guitar novice
    Perth
    You will notice in the last photo that the first join I did between front and back blank was not perfect. The bottom piece on left side shows a small gap. When gluing the 2nd blanks I used more glue and cranked the clamps more. It came out much better.
    The issues after joining was that the 2 sides were not level. Only slightly out so hit it with a palm sander.
