Guitar Maintenance and Temp
Discussion in 'Amp Tech Center' started by idflyfish, Oct 12, 2019.
  1. idflyfish
    idflyfish TDPRI Member
    Boise
    Hello Everyone,
    I have a workbench in my garage but with winter coming on I'm concerned about doing maintenance there due to temp. I have recently bought a plug in heater which should keep the area warmish. Should I be worried about temp? If I have a heater and the outside temp is above freezing should I worry? I know this is a strange question but I'd be interested in your thoughts.
  2. rangercaster
    portland, or
    The simple rule to follow, for me ... If you are comfortable in an environment, it's fine for a guitar ... I wouldn't like to spend 8 hours in the trunk of a car on a hot day, or any day for that matter ... Any extremes of temperature or humidity or aridity are to be avoided ... Attics, basements, garages, sheds ...
    Maybe a bit much, but better to err on the side of caution ...
  3. Deeve
    Deeve Friend of Leo's
    Ballard
    yes - personal comfort rule works.
    I can't remember humidity & temp ranges but I know when I'm uncomfortable. And yer D28 can't "put on a wooly sweater"
    Peace - Deeve
  4. rolandson
    rolandson Tele-Meister
    Cascadia
    You're in Boise? Outside temperature above freezing? Surely you jest.
    Your comfort is immaterial, it's the temperature of the guitar that's relevant. Temperature has a significant affect upon the wood.
    If the heater is sufficient to heat the area of the bench, without blowing warm air onto your work...sure, you'll be fine. But if you expect reliable results with a heater blowing hot air on the neck you're trying to adjust, forget it.
