Guitar Identification
Discussion in 'Other Guitars, other instruments' started by LWP11, Jan 27, 2020.
Tags:
  1. LWP11
    LWP11 TDPRI Member
    OHIO
    Hello, I am new to the guitar world and Im not very knowledgeable when it comes to some of the earlier models. I have an old Fender electric guitar serial number 20594. Ive found a little info on the date based on the ser number which appears to be around the late 50s. If any one has any info regarding age, model and value....id appreciate it.
    thanks
  2. ale.istotle
    ale.istotle Tele-Meister Silver Supporter
    Pennsylvania
    Appears to be an old Duo-Sonic. Two-pickup variant of Musicmaster which is written on your headstock. Short-scale student guitar. They shared a common neck in the first gen guitars. No idea of the value, but that should be enough for you to search around.
    Greggorios likes this.
  3. Rev Rhythm
    Rev Rhythm Tele-Holic
    New Orleans
    I'm no expert but a quick look at Fender's serial number dating, and a little info about when they stopped using that anodized pickguard tells me it's probably a 1958 Musicmaster.
    Greggorios and ale.istotle like this.
  4. BigDaddyLH
    BigDaddyLH Tele Axpert Ad Free Member
    Kelowna, BC, Canuckistan
  5. Greggorios
    Greggorios Friend of Leo's Silver Supporter
    Patterson, NY
    Looks VERY interesting. Hoping that someone here can suggest someone near you who can help identify specifics for you. Please be careful with it, particularly taking it apart if you don't have any experience. Best luck with it. Hope you'll keep us updated. Lucky you!
    nojazzhere likes this.
  6. 2blue2
    2blue2 Friend of Leo's
    Island of Oahu
    Sweet!
  7. matmosphere
    matmosphere Tele-Afflicted
    earth
    It’s probably a ‘59 Musicmaster. The gold pick guards were done across the board in 1959 so that’s a giveaway. It would have only come with the neck pickup that looks original. The other was probably added later.
    it was a entry level student guitar and I think they were made earlier than the Duo-Sonics ever were.
    cool guitars! I’d hang onto it if I were you!! Looks like somebody played it a lot, which means it’s probably a pretty fun guitar to play.
    Not worth a ton, maybe $6-700 but probably less. Looks like the finish was probably stripped and redone. Don’t think they had a natural finish option in 59.
    Most of those have a shorter scale than most fenders, which is probably why the values aren’t super crazy. Think it’s a 24” scale for most, and a standard 25.5” could be custom order but was rare.
    My advice is to find and amp plug it in, crank the volume and have a blast. That’s a sweet little find! Whatever you do don’t sell it. You’ll never get another one again, and you will want it back if you sell it.
    Torren61 and Greggorios like this.
  8. ElJay370
    ElJay370 Tele-Holic
    Los Angeles, CA
    As others have said...Late 50's Fender Musicmaster.
    The body has had it's finish stripped off and looks to have been heavily sanded. The bridge pickup is a later addition. They originally only came with one pickup. A few changed screws here and there also. These things will absolutely affect it's value to a collector. On the upside, everything else looks good and it's as well made as any 1950's Fender guitar. How does it play?
  9. matmosphere
    earth
    LWP11 and Greggorios like this.
  10. dogmeat
    dogmeat Tele-Afflicted
    Alaska
  11. jayyj
    jayyj Tele-Afflicted
    Manchester, UK
    Agree, refinished Musicmaster with added pickup. Duo Sonic and Musicmaster bodies were taken from the same pile so adding a pickup to a MM only involves cutting the pickguard, the routing is already done.
    A nice condition all original MM from '58-'59 would typically sell for $1800-2200 depending on the dealer. Nicely refinished body and you're probably down to $1200-1400, and amateur refin and further mods probably $600-800 or so. Many of these get parted out in which case it's probably worth $800 in parts.
    Here are my two, Duo from '58 and a refinished '63 Musicmaster.
    LWP11 and ElJay370 like this.
  12. LWP11
    LWP11 TDPRI Member
    OHIO
    The guitar was actually my grandfathers and way back in the day he was in a couple bands. He said over the years out of all the guitars he owned....this one was the smoothest best feeling guitar he ever played. Ive messed around with it here and there but im more into the drums. seems to play pretty nice though.
    thunderbyrd likes this.
  13. LWP11
    LWP11 TDPRI Member
    OHIO
    Thank you all for the info. I greatly appreciate it.
    RoscoeElegante likes this.
