loopfinding
is that supposed to be grilling sliced onions?
What the heck folks. Do you like your girlfriend? Yes. no, it depends, which one? This question doesn't need to be clarified to its smallest nuance.
Did you remove the neck to scrape the body?
The poll question is posed as though you’re seeking knowledge, and you’re getting carefully considered answers but you’re complaining about them. Have you considered revising the title, question or poll options in light of the initial answers you’re receiving?
I don’t know to what degree finish affects instrument sound, because the guitars I’ve had with different finishes and sounds also varied so much in other ways that I don’t know what to attribute it to. There’s no poll option for me, but there’s my guitar finish/sound input.
I don't think enlightenment is the motive here.
Yikes, not thatI think OP is Blowtorch trolling us.
Hey man, do you like The Beatles?
New strings + re-attachment of the neck = change of sound.Of course. I hope that's not intended to be a "trump card".
They really don't.Since strings resonate from the vibration of the wood, there has to be some impact albeit slightly.
You have no way of knowing if removing the finish made any difference at all.
This is pretty much what I was going to say, and I was also going to use an SG as the the example. In my case, a 1981 SG with a poly finish so thick, it looked like it had been dipped rather than sprayed. The finish was original, but it was not done correctly. Major orange peel, clouding, bubbles, and discoloration. There was something seriously wrong with the finish from day one.But I inherited a 61 Les Paul (SG) Standard that had been refinned in 2mm thick poly. I had it stripped and finished in nitro. It was like releasing a guitar that had been entombed in thick plastic to breathe again. I can hear that massively and so did my tech who did the work.
So I'd conclude that the audible difference is generally slight, if apparent at all, but in extreme examples like the SG it can be massive.
