Groove Tubes
Discussion in 'Glowing Bottle Tube Amp Forum' started by gibson11, Jan 6, 2018.
  1. gibson11
    gibson11 Tele-Meister
    Milwaukee, WI
    Have the EL34's in my Music Man for about 10 years now. At low volume it sounds kind of buzzy and trebley, would JJ's be an improvement?
  2. JustABluesGuy
    JustABluesGuy Friend of Leo's
    Houston, TX
    Have you had the same brand, or the same individual tubes in it for ten years? Has it always been buzzy with the groove tubes, or is this recent?
    If you actually have ten year old tubes in it, it’s likely that any new tubes (regardless of brand) would be an improvement.
    viccortes285 and DougM like this.
  3. MrGibbly
    MrGibbly Tele-Afflicted
    SATX
    In my experience, the preamp tubes have more to do with these kinds of sonic symptoms than the power section most of the time (especially at low volume). There aren’t many factories making tubes anymore so there really aren’t too many huge differences among newly manufactured examples of a given type (testing/quality differences aside). I’ve had good luck with both JJ and TungSol preamp tubes in my Peavey and Marshall. The Tube Store website has a lot of decent information about the various manufacturers, tube types, etc.
    JustABluesGuy likes this.
  4. Syrinx
    Syrinx Tele-Holic
    Champaign illinois
    As said before any new tubes may sound better than old ones! And of course GT tubes could be anything. The GTs in my custom champ are 3 different brands.
  5. muscmp
    muscmp Tele-Afflicted
    california
    pull them out and put them back in a few times. if you still get the noise, you may want to try deoxit on the pins and inside the socket. another possibility is to swap the power tubes and swap the preamp tubes, one by one. if this identifies a bad tube then you'll know which to purchase.
    play music!
  6. DougM
    DougM Poster Extraordinaire
    Honolulu, HI
    Music Man amps don't have preamp tubes. SS preamp and tube power amp.
    Dan R likes this.
  7. MrGibbly
    SATX
    I stand corrected, thank you!
  8. JD0x0
    JD0x0 Poster Extraordinaire
    New York
    Groove tubes are rebranded tubes from other manufactures (mostly Chinese, I believe)
    Nothing wrong with Chinese tubes, IMO, but know what you're paying for, and that they're just Chinese tubes, tested, relabled and sold for more money.
  9. Dan R
    Dan R Poster Extraordinaire
    Charleston, SC
    I had a Music Man RD-50 for about 30 years. This one had two 6L6 power tubes. As stated, SS preamp, only power tubes. I had GT''s as the first replacement after about 15 years. I then got some JJ's later. I don't know that I could tell much difference. I think amps like that are not finicky. As long as a tube works and meets spec, good to go. JMHO
  10. ebb soul
    Smyrna georgia
    Hold the press.
    " nothing wrong with chinese tubes'
    Has the world froze over?
    There must be a landfill a mile high with all the chinese tubes tdpri ers have thrown out, mainly because the other guy did.
  11. clintj
    clintj Friend of Leo's
    Idaho
    I like the Shuguang ones in some applications, personally. Mesa and Ruby like them too, from what I've seen.
  12. ebb soul
    Smyrna georgia
    I 've been saying thses amps are voiced for these tubes forever and get totaly lambasted for it.
    Yet less than 20 % are happy when they exchange them for something else.
  13. Televised
    Televised Friend of Leo's
    Portland, OR
    I've had good luck from Tung-Sol's and JJ's in the power tube department.
    The Tung-Sol's are now New Sensor/Sovtek - Russian. I think this includes EHX, Mullard, Svetlana, along with the Tung-Sol's and Sovtek and whatever I'm forgetting, (I purchased a Mullard 12AX7 and to my surprise found out it was identical to the Sovtek-LPS I had).
    The JJ's are Slovakian with Eurotubes being their primary distributor I believe.
    Shugang as mentioned above are Chinese and as noted above Ruby is one brand that comes to mind. Some are rebranded as Mesa and GT with some occasional Russian tubes mixed in with the Mesa's.
    Those are the three big makers of tubes that I know of and jive with what I'm reading in this thread.
    So back to earth and your question, "Yes". As of late the Tung-Sol's seem to be a slight preference to me for tubes lately than the JJ's but I actually use both and it depends on which tube I'm replacing. I also think you'll be happy with either one.
    I also seem to prefer the Russian and Slovakian tubes over the Chinese but this is strictly a subjective preference in the tone. There is nothing wrong with the Chinese tubes and I think that Shugang's are fine tubes.
    It's more of a choose what flavor you like versus a particular brand of tube being bad.
    Hope this helps with your amp tone!
    viccortes285 likes this.
  14. gibson11
    Milwaukee, WI
    My Music Man does have a SS pre-amp, will try and move the 4 tubes around and see if there is a culprit, thanks all
  15. DrBoBo
    DrBoBo TDPRI Member
    Downers Grove, IL
    If you do decide to purchase JJ's get the E34L tubes. The E34L has a slightly higher grid voltage rating (-13.5 to-16.5 vs -10 to -13.5 volts) than the traditional EL34 vacuum tube. A good idea since MM voltages can be _very_ high. Don't forget to re-bias.
    DrBoBo
  16. Wally
    Tubes from GT could be Chinese, Russian or JJ’s. There is a code that indicates the country of origin. R for Russian, S for JJ.... I don’t pay for that high dollar silk-screening that GT uses. Ymmv.
    IMHO, Gibson11, your amp would do well to be in the hands of a tech who has some experience in MM amps. Your amp runs very high voltages on the plates.....700+. These amps want to be put in proper working condition and maintained well. 10 years is a long time without some tech oversight, imho.
  17. Syrinx
    Syrinx Tele-Holic
    Champaign illinois
    The GTs in my fender custom tweed champ actually have ruby on one,the word russian on the other-and the preamp tube nothing other than the GT logo all have.
  18. tubejockey
    tubejockey Tele-Holic
    the bozone
    Nearly every tube amp ever made has the problem of thin trebley sound at low volume. That's why we play them loud.
  19. Dacious
    Dacious Poster Extraordinaire
    Godzone
    I've had a couple Shuguangs go out in cathode follower stages, but then so do NOS tubes. Shuguay are cheap to keep a few on hand.
  20. radiocaster
    europe
    This isn't the only forum.
    That landfill is probably smaller than the landfill full of non-broken-in speakers.
    ebb soul likes this.
