Gretsch from the 1800s brought into the 20th Century
Peegoo
Beast of Bourbon
Well, it's not really from the 1800s, but the technology is. This is a Gretsch New Yorker I've had for the past 12 years. It's a true archtop with a carved top of solid spruce with no center trestle like most hollow Gretsches have. The tops on these are pretty thick, so they're not known for being light and airy sounding. This one does not have much volume even with big fat bronze strings on it. So over the past few years I've been contemplating sticking a pickup in this to electrificate it. Today was the day.
I have a bunch of derelict pickups in my parts bins so I found a nice medium-power Gibson P90 for it. I marked and cut for the base of the pickup to fit under the strings because it would be just a little too close to the strings without inletting it into the top. The tone bars under the top were spaced perfectly to accommodate the pickup (dumb luck). I drilled three holes for volume, tone, and output jack. The jack is on the top rather than the side because I've lost count of the number of times I've had to repair other players' Gretsches that have the side jacks busted out of 'em.
I drilled through the tail block for the string ground wire, soldered up a wiring harness, and dropped it all in through the pickup hole. If you've ever worked inside a hollowbody before, you'll know it's not a pleasant experience unless you know a few tricks. This one went extremely well because I planned all the moves, and the harness allowed all the parts to slip right into place. I tested the circuit and everything works, with ground continuity to the tailpiece.
It's not strung up yet because the fret ends are a little sharp in places, so tomorrow I'll hit 'em with the file and smooth 'em all out. I also need to notch out the pickguard to accommodate the end of the pickup and reinstall it.
This guitar will be open-tuned for slide stuff. It's got the right pickup and the right vibe for it. Sort of a poor-man's ES125.
Joebanjocolo
Ute Pass Colorado
Nice! I have a Gretsch G100 that I have been thinking about doing the same thing with it!
AAT65
West Lothian, Scotland
Nice work! I admire your skills and confidence:) and I like how you marked the corners of the floating bridge… then found that the tan lines would have told you where it sat anyway!
Wallaby
Here
I'd like to hear what it sounds like once it's up and running again.
Making that first cut/hole/whatever was kind of crossing the Rubicon I imagine!
Peegoo
Beast of Bourbon
I've done a few conversions like this in the past. One was a Washburn HB15 (cheap jazz box with a single neck-mount mini hum).
I wanted an ES175 type of beast but didn't want to spend the $2000+ for the real deal because I already have too many Mucho Dinero guitars. This Washburn is built similarly to the Gretsch, but the top is thinner, made of laminated mahogany. I leveled and polished the frets and installed a bone nut as well. It came out way better than I expected and plays like a mo-munny guitar.
Click on pic to embiggen.
Peegoo
Beast of Bourbon
Okay...I took care of the sharp fret ends, polished 'em up, cleaned up the guitar and vacuumed out all the beaver dust. Strung it up with 11s and dialed in the action and intonation and it plays and sounds great. I just spend the last hour running through some jazz standards I haven't played in a long time. It sounds super smooth and mellow. Happy happy!
I may leave the pickguard off...I like the way it looks, and the string action is not so high off the top that I need a finger rest. Time will tell.
If you're considering doing this to a birdhouse guitar, go for it. It's not that difficult once you get the layout for the pickup in the right spot.
tomasz
Europe
Looks much better without the pickguard! The most important is, you are happy with the sound ;D
Peegoo
Beast of Bourbon
You are fearless Peegoo. Nice work.
Cheers, brother.
I passed through Uvalde two weeks ago on my way from San Antonio to Del Rio and back. I could live there and love it. Last time I saw Billy Joe Shaver (RIP) was a few years ago at the 501 Ranch just south of town.
