Great cheap acoustic pickup
Discussion in 'Just Pickups' started by Chunkocaster, Dec 8, 2019.
  1. Chunkocaster
    In space with Ziggy
    A few months ago I installed a Belcat SH-85 soundhole pickup in my Sigma d-35 copy dread.
    I plugged it in for the first time today and was surprised how good it sounds considering it cost about $20 bucks delivered.
    If you are in the market for a cheap acoustic pickup I recommend checking these out. I think the pole pieces can be adjusted by pressing in and pulling up with pliers but will have to check on that. I didn't do a permanent install, just run the cable around the back of body and hung the jack end on the strap pin. I'm now considering installing it permanently and maybe adding a K&K type pickup to use in conjunction with it and blend the two together.
    I had a Martin dcpa-4 acoustic and imo this sounds better plugged in than that did.
  2. YoGeorge
    YoGeorge Tele-Afflicted
    Michigan
    DO NOT USE DUCT TAPE ON A GUITAR FINISH!!!!! Maybe blue masking tape or something.
    Chunkocaster and Fretting out like this.
  3. Zepfan
    Zepfan Poster Extraordinaire
    Horn Lake, MS
    They do make end strap pin jacks for acoustic guitars.;)
  4. Musekatcher
    Musekatcher Friend of Leo's
    meridianam altum centralis
    Its hard to evaluate an acoustic pickup by yourself, because you are hearing the guitar plus the pickup sound - unless you REALLY crank it. I used to think my pickups sounded great, then I went for a beverage, and heard a peer playing my flattop from the bar - not bad, but nothing like what it sounds like under my ear - of course.
    Chunkocaster likes this.
  5. Fretting out
    Fretting out Tele-Afflicted
    Land of Mary
    Woe! Chunkocaster! You scared me for a minute
    I read through quickly and thought you put all that tape on a Martin
    At first I was thinking I probably wouldn’t put tape on my guitar but it’s yours to do what you want with it
    Keep on rocking
    It must be too early... in order that I read:
    First it was
    A Martin guitar
    Then a belcat guitar
    And now a sigma
    I’m gonna stop reading it again now next it will be a k&k guitar
  6. Ronkirn
    Jacksonville, FL
    Gasp!! My thoughts exactly. specially on a D-35... I would be a but hesitant to clamp a pickup across the sound hole too..
    r
  7. Chunkocaster
    In space with Ziggy
    It's poly, nothing can damage it. Not even gaff tape.:)
  8. Chunkocaster
    In space with Ziggy
    Yeah I have one in the spares box. The lead and plastic plug end came with the pickup. Nice and easy to install using gaff tape.
    Zepfan likes this.
  9. Chunkocaster
    In space with Ziggy
    I playe it through a Marshall 50w acoustic amp turned up loud. Sounded great.
    I was listening for my guitar but couldn't hear it over the amp.
  10. Chunkocaster
    In space with Ziggy
    It's a great lookalike Martin D35, A sigma DR35 with thin poly finish. Solid top laminated rosewood back and sides. I sold a Martin dcpa4 when I bought this Sigma.:).
    It's loud acoustically with a low action, fitted with 12's and I can play lead and just about anything I can play on a electric on it.
  11. Chunkocaster
    In space with Ziggy
    It's built like a tank. Thin Poly finish.
  12. stepvan
    stepvan Tele-Meister Silver Supporter
    amherst
    :D
    Man tape that B**tch up if ya want haha. I have been wondering about that pickup for awhile Its always on the back burner but maybe put steels on my harmony and install that pickup
  13. Chunkocaster
    In space with Ziggy
    I really like it, I just bought it because it was cheap and I needed something to play through a pa when jamming with friends. It surprised me.
  14. Peegoo
    Peegoo Tele-Holic
    If it's catalyzed polyester (like just about every import guitar), not even finish stripper will damage it. The only thing it yields to is fire.
  15. Ronkirn
    Jacksonville, FL
    Poly?? On a D-35?? you sure about that? Izzat a Martin or a copy?
    rk
  16. Chunkocaster
    In space with Ziggy
    It's a Sigma DR35, a Martin copy. It's a nice lowish cost guitar.
    $550 bucks and I got to pick it out of a selection of 6 the same after playing them all and comparing in one sitting. Quality was inconsistent but this one was a standout, by far the best of the bunch in sound and playability. I set the action low like my electrics and it still projects and sounds great.
  17. Zepfan
    Horn Lake, MS
    I figured it was temporary, just having fun at your expense.:D
    I put a flatpup on my acoustic CBG with double sided tape to temporarily test it 2 years ago, still there.;)
  18. Chunkocaster
    In space with Ziggy
    It will probably be some time before I install it properly, about the time the tape falls off.
    I did take the tone into consideration hence the minimum amount of small pieces of tape spread out.:)
    Zepfan likes this.
  19. Zepfan
    Horn Lake, MS
    Should've used the tan and brown duct tape for a camouflage effect.
