Gotoh In-tune brass saddle height adjusting screws
Discussion in 'Tele-Technical' started by PeterUK, Feb 3, 2021.
  1. PeterUK
    PeterUK Poster Extraordinaire Silver Supporter
    Nottingham, UK
    We think alike. I use a business card and eye in the saddle position for intonation and also adjust the saddles for radius using a radius gauge.
    I have to confess that on one bridge I got the saddles positions, height and radius 'almost' perfect. The intonation and radius required the tiniest of adjustment once I set the action and adjusted the truss rod.
    I'm never too far off but on this one occasion I was so, so close!
    BTW, I wish we had a McMasters Carr on this side of the pond. I can get every conceivable metric size but I'm really struggling on Imperial.
    I do have some 6-32 grub screws but I can only find Gavin at Axecaster who stocks them as an extra for his vintage saddles.
    Anyone else in the UK know of a local supplier.
  2. yegbert
    yegbert Poster Extraordinaire
    Maryland (US)
    A business card under the saddles? I guess one would easily cover the area under all of the screws and probably be a little more sturdy. I’ll have to try that!
    PeterUK likes this.
  3. Tele-phone man
    Tele-phone man Tele-Afflicted
    Asheville, NC
    Timely thread. I just did the exact same thing as the OP on my Tele. I ended up replacing all six of the 10mm screws in my bridge with 8mm pieces. My palm could not be happier.
    PeterUK likes this.
  4. yegbert
    Maryland (US)
    I haven’t tried it yet with the threaded steel saddles like I was thinking, but I’ve now made my own compensating grooves in a set of straight fat (5/16” inch or so in diameter) *brass* saddles.
    These were a set I got from fleaBay, an Asian made bridge. They were chrome plated brass with small straight grooves, and incidentally I removed all that chrome with a dremel-like tool with a slightly abrasive brush-wheel. I opened up the grooves deeper, slightly wider, and staggered (eyeballing an RS Guitarworks set) with a cutting disc and then polished them again with the brush.
    The bridge with the staggered-groove-compensated saddles is mounted to the guitar here, it’s the gold plated one. To its left is a 2006 or so Squier Standard with either Gotoh or MIM Standard 6 block shaped saddles that I was thinking about using but decided I might need to cut the springs or use shorter saddles to get it intonated. The gold bridge is stringed top-loaded.
    The guitar intonates correctly with these.
    PeterUK likes this.
