Gotoh 6 saddle bridge (GTC202) compatibility with current American Telecasters?
Hodge
London
Can anyone advise if the Gotoh 6 saddle bridge (GTC202) would act as a direct drop in replacement for the vintage style bridges on both the current AM Professional and AM Performer Telecaster? I’ll likely be picking one of these up soon and I imagine I’ll be looking to change the bridge in the future.
I have installed a GTC202 previously to both a Classic Series 72 and a Japan 62 Custom Reissue without issue, but I’m unsure about the current AM models.
Having reviewed the AM Pro bridge; I think it’s unlikely it will work as it seems the string holes are now above the mounting screws, however; I believe it should work without issue on the AM Performer Telecaster as I believe that model utilizes a standard vintage style bridge (string holes below mounting screws)
If anyone has actually done this or can offer any advise it would be greatly appreciated.
Tuxedo Poly
Merseyside UK
The Professional has the same fixing and through hole positioning as the the American Standard which is modern.
The Performer bridge is the "Pat Pend" which is the same screw fixing and string hole positioning as the GTC202.
244300
Phoenix — Biltmore
Are there any tips or tricks for installing a bridge or is it just unscrew the old one and screw in the new one?
Should Loctite 242 or 243 be used on the screw threads?
boris bubbanov
Tele Axpert
New Orleans, LA + in the
I wouldn't use either. Let the fastener, and the wood, do the work. If the wood is punky, such as Paulownia, you may need to go to a larger diameter or longer screw to get solid purchase.
Tonetele
South Australia
What’s the difference between a brass saddles and steel saddles?
Firstly Gotoh Bridges fit perfectly. I dropped one in my Hwy.1.
Secondly brass bridges are usually chrome covered in these but the brass factor seems to have a more mellow sound.
I like the steel ones if you want brighter sounds.
Beachbum
Sand Land
It was a drop in fit for my American Standard and Special Edition Koa with the exception of be prepared to shim the neck to compensate for the extra thickness of the Gotoh base plate.
WzuY8rIDPJLEG9pvrDxE-m6A86SqmabA6N8F6QCC3YJI0Fq_R3R495whInN5rLfKcIrGj07LtRQjh6HvbdkhqsF4duDjokiXM3AF_amI-P-g0U2TN80TepQfdUzDjR6tA3NEn07MpXQeFdRtMF6WdjEQf_Ot08L9EgTm6-7w-D0XF7O2fTTLssCvWmnxxdMc4dmV-ZHP_VAUxq3COOtB-rKISmyePjXpN4XM6RJhsYCrv98JYDhHKLFL9zvNcBcw-T-OgqpR-iLh-0t1GfmvDBVgsWgX9cQ82bA_MCjSNrJBGBfadUP3vwktw-09uDtccjgpafoaI0zO_vLrGag-LLuSDIn7N7snWW3c3xhfJMzShckCg-GMk1iZ3z4tZ3QueI3BuocmUxw7FHsvl19DGAuG3ZQQDmiZIpgHU9Udvmld7NcjUfQjuI8twIFV0fgpCLud79aAD3dlqBEZsT2o0j2WIj4aM_1rcWUGlE9CztZsTOwsornkPE4kOGDT6nHz07fKTrKO_AbFyjPCrIZOirYRmMvk7jyJF4k5T296gBgEgmY2-IBP4A4ug42h-5tZDSE8TbQ-b24vSWZwEaNQNL7-z1IKzlNNT4ASKtJsN4qB4umHplh-d1hiAkvbqrFnVi56wibT4fyuGXGStIyCVC3O22C7IZtIEl3CObLyKLE9wb6V9KCcDr3t3XGWLBrlmK1gE4lwJerk1PUGzzcVU8JU=w470-h640-no
Don Mare
CA.
everytime we replace a tele with 6-saddles here in the last 21 years - we lost tone - a lot of tone - that reminded me of why Old Timers would Mod Strats to 3 Brass Barrels - seems the down pressure of two stings are better then one like the old saying TWOS better Then One
