Goodrich model 120 volume pedal problem
Discussion in 'The Stomp Box' started by lliw, Nov 2, 2014.
  1. lliw
    lliw TDPRI Member
    Ithaca, NY
    The pot doesn't seem to be worn out in the typical sense (it's not crackling), but the sound cuts way down when rocked forward to full volume. The rest of the sweep sounds beautiful, but then the last little bit at the end makes the volume drop. Everything appears tightened and in place. Could the string have slipped over the years? Is the pot being forced past it's "full-on" position?
    Any suggestions? Should I restring it?
    THANKS.
  2. Joe Gagan
    Joe Gagan Tele-Meister
    Albuquerque NM USA
    first, try to disconnect the string without unwinding using a vicegrip to hold the retained end so you can manually rotate the pot while listening to determine if you exceeded the physical stop inside the pot.
    there is not a situation i can think of that would act the way you describe unless the string is maladjastuted AND the pot is exeeding the regular path.
  3. lliw
    lliw TDPRI Member
    Ithaca, NY
    I loosened the set screw and backed off the tube (the one on the pot shaft) just a bit. I think this may have it fixed. Now the pedal hits its mechanical end before the pot does.
