Greg70
Hi guys!
OP here!!
pretty good advices and Tips (pun intended!)
okay so, Hakko, if not Weller, if not just generic ones! I’ll try to spring for a Hakko - probably used.
i now own a strat, so i might go crazy with Loaded pickguards that I might interchange depending on my mood!
may I ask what do i need to put in my shopping list besides the soldering iron/station?
1. Interchangeable tips?
2. Sponge???
3. What kind of metal wire do i need to use?
4. Whats the lead for?
5. Whats a dipping tray?!? Lolol
i feel like I’m gonna open pandora’s box once I learn how to solder. Lol. But still, soldering is my no.1 priority in learning, then I’m gonna buy some luthier equipment and buy some fret work and nut tools! Lololol
The Hakko comes standard with a small chisel tip that works great for just about everything. If you buy used there's no telling what it might come with, but tips are cheap and easily replaceable.
The Hakko comes with the brass sponge for cleaning so you won't need that separately.
Not sure if by "metal wire" you are referring to the wire that you are installing. Most guitar and amp stuff is 22 gauge pre-tinned wire. If it's available, the cloth-covered "push back" wire is kind of nice because you can push the insulation back away from the cut end, solder your joint, and then slide the insulation back down over the wire. It's a little quicker and cleaner looking than trimming plastic insulation off the wire.
The lead is the type of solder. It's an alloy of tin and lead that allows for the relatively low melting point. A lot of newer solder is lead-free. I've never used lead-free but I have heard it's a little harder to use and requires higher temps. You also don't want to mix them. Because of the lead content, some countries no longer sell it. It's still available in the US but I'm not sure about other places.
