Pat_rocks92
I mean it would be too big and heavy and i'm already using a 18w chassis for the build to save some space :But it's a push pull amp. You need to add 2 tubes for an extra output stage, but then you'd have a 100watt with the pre-amp section of the 50 watt version.
What do you mean with
Do you mean that the 100watt would be too loud, or you don't have a chassis big enough for the 100W amp?
- Width: 430 mm
- Depth: 170 mm
- Height: 65 mm
