going back to originals and shielding
Discussion in 'Telecaster Discussion Forum' started by teleplayer99, May 14, 2021.
  1. teleplayer99
    teleplayer99 Tele-Meister
    birmingham, al
    Where would you shield. I have thought of under pups and the cavities with and overlap of the copper. What about under pots input jack and pickguard? Any where else. I have plenty of copper and enthusiasm. Liked gen 4 noiseless, but want guitar to be original. I mean what tele has a hand-rubbed nitro finish? Its just another fender limited run, but its mine and a keeper.
    Fendereedo likes this.
  2. Killing Floor
    Killing Floor Friend of Leo's
    Austin, TX
    I do all the cavities I can reach. I do the underside of the pick guard. And I connect the shielding to ground. I normally use copper tape. I don’t know if that’s best.
    Maguchi, teleplayer99, Boreas and 4 others like this.
  3. myteleplaysjazz
    myteleplaysjazz Tele-Holic
    Lakeway, Texas
    Yep. Plus one.
    Maguchi, teleplayer99, Boreas and 3 others like this.
  4. Fendereedo
    Fendereedo Poster Extraordinaire
    England
    Cavities with copper tape, and under the pickguard. I once tried a paint that was water based, and it just sat there in pools, and ran off the cavity walls. Never making that mistake again.
    teleplayer99 likes this.
  5. Bongoslade
    Bongoslade Tele-Meister
    Delaware
    i was wondering myself
    do you guys cut a paper a template to see how it fits - or just wing it and solder it together where it's spotty?
    Boreas likes this.
  6. RLee77
    RLee77 Friend of Leo's
    Nevada
    Use strips that lay down flat, don’t try to cut one piece and mold it in, it will bunch up. Use a bit of solder to connect the strips, don’t rely on conductive adhesive. Copper tape solders very easily. Oh and take care trimming the excess foil — I put a scratch on my body finish with the exacto.
  7. RLee77
    Nevada
    I do the neck cavity, and control cavity, but not the pickguard, and my tele is very quiet.
  8. Wallaby
    Wallaby Friend of Leo's
    Here
    This works for me -
    If your tape is wide ( I use 3" aluminum tape from Home Depot ) you can use the tape itself instead of making a template by positioning the tape over the portion of whatever cavity you're working on and pressing along the edge to create an impression on the tape, and then cutting along the impression line with scissors to get an exact fit.
    For curves like a cavity wall I make small snips along the edge ( sort of like kerfing ) to allow the tape to overlap onto the bottom of the cavity without bunching or wrinkling. If you do the cavity walls first the piece covering the bottom of the cavity will lay over the "kerf" edge of the wall piece and hide them for a neater appearance.
    Using the widest possible tape allows you to use the fewest pieces - for a Tele control cavity I'd use two pieces - one for the entire cavity wall and one for the bottom, with the bottom piece hiding the bottom edge of the wall piece.
    Aluminum doesn't solder ( at least for me! ) so a small folded-over piece of tape in a strategic area will provide electrical continuity.
    Careful work around holes with an X-Acto knife here and there, too, help avoid that "smashed-together" appearance.
    teleplayer99 and AAT65 like this.
  9. myteleplaysjazz
    Lakeway, Texas
    I make a tracing from the top of the cavity, then cut the copper tape just a little bit bigger. I want the tape to sort of "crawl" up the side of the cavity about an 1/8 inch or so. This gives me a good overlap when applying to the side. Then, just to make sure I have on a belt and suspenders, I'll put a spot solder joint at seam.
    I say "tape" but its really a sheet. And the copper sheet should have conductive adhesive on it. StewMac makes the perfect product.
    teleplayer99 and Bongoslade like this.
  10. TheMicster
    TheMicster TDPRI Member
    Mt. BawBaw Victoria Australia
    Do you find that the conductive adhesive fails after a certain time or is just not reliable?
    Boreas likes this.
  11. Boreas
    Boreas Friend of Leo's Silver Supporter
    Adirondack Coast, NY
    Some people say yes, but not in my experience. If you want, just flow some solder at the overlap points.
    Bongoslade likes this.
  12. DavidP
    DavidP Friend of Leo's
    Vancouver BC, Canada
    Consider getting a 1 foot square of copper shielding. I prefer that to tape as I can custom cut it to completely cover cavity bottoms. I align the sheet over the respective cavity, gently press to get an outline and then cut with a 1/4 inch outside overlap so it extends up the sides a little. It can be a little delicate (and frustrating) to insert but patience pays off! And after I do the sides, I'll tack a dab of solder on the overlaps, regardless if it's conductive adhesive to ensure continuity no matter what.
    Here's a finished job on a strat.
  13. myteleplaysjazz
    Lakeway, Texas
    I have never had conductive adhesive fail, but I do spot solder the joints - maybe that's why???
  14. RLee77
    Nevada
    I measured resistance at several points over several days, and found it varied quite a bit. Probably fine, but since the copper is extremely easy to spot solder, why not remove all doubt.
  15. noname_dragon
    noname_dragon Tele-Holic
    North east coast
    Does the shielding change the tone of the output sound?
  16. jayroc1
    jayroc1 Tele-Meister
    vancouver
    I've heard the input jack route doesn't need shielding
    Boreas likes this.
  17. RLee77
    Nevada
    Some say yes; others no. I haven’t experimented with it yet; I may on my current tele build. It’s the sort of experiment that needs careful setup and procedure to be meaningful.
    I tend to think it makes a slight difference, but nothing that a little tweaking of your tone controls can’t correct.
  18. Boreas
    I usually use shielded cable to the jack. If not, I twist them. Can't hurt.
    myteleplaysjazz and RLee77 like this.
  19. DavidP
    Heads up -- if you do shield the input jack, you should check that the jack tip does not contact the shield when a cord is plugged in, or you'll short out the connection! If I do shield that area, I'll also put a piece of electrical tape on the outer side of the jack tip, as preventive maintenance.
    Dixon in Korea and teleplayer99 like this.
  20. AAT65
    AAT65 Poster Extraordinaire
    West Lothian, Scotland
    I think shielded cable to the jack is a better option than trying to shield in there: simpler and if anything more effective.
    czech-one-2, Laren, jvin248 and 2 others like this.
