Gluing up body blanks.........
Discussion in 'Tele Home Depot' started by J Lacey, Jun 5, 2012.
  1. J Lacey
    J Lacey Tele-Holic
    North Georgia
    How long do you usaully wait to take the clamps off after gluing up several pieces that make up a body blank? Thanks
    Jeff
  2. adirondak5
    adirondak5 Wood Hoarder Extraordinaire
    Long Island NY
    I usually let mine sit over night using Tite Bond original .
  3. Bill Scheltema
    Bill Scheltema Tele-Afflicted
    Palmerston, Ontario
    I use titebond original too, and let it sit overnight as well.
    Bill
  4. Mike Simpson
    Gilbert, AZ (PHX)
    60 to 90 minutes then I unclamp and clean up the glue squeeze out with a wet rag.
    I use titebond original, the directions say to clamp an unstressed joint for 30 to 60 minutes.
  5. guitarbuilder
    one hour in most cases assuming you are working with properly prepared joints.
  6. J Lacey
    J Lacey Tele-Holic
    North Georgia
    Thanks...........I used tite bond . Just wanted to make sure before I unclamp anything. I appreciate the info.
    Jeff
  7. volowv
    volowv Tele-Meister
    maine
    mike, i think the directions say 30-60 minutes before unclamping, and not to stress the joint for 24 hours. i've planed a blank after 90 minutes with tightbond 1 with no ill effects.
  8. Guitarnut
    Guitarnut Friend of Leo's
    +1
    No need to leave it clamped up any longer. Doesn't hurt, but if you need the clamps for other tasks, you can unclamp after an hour and then let the blank rest over night. Truth be told, I've worked blanks after a few hours and never had an issue.
  9. Bill Scheltema
    Palmerston, Ontario
    Hi guys,
    Since we are dealing with a thick piece of lumber the glue will not have set completely in an hour.
    I found when working in the furniture industry then you will get shrinkage from not letting the joint cure adequately and moving on th planing and thickness sanding,there was always a noticable joint line. Whats the hurry anyways. Glue it up before heading to bed then un-clamp in the morning.
    Bill
  10. OpenG Capo4
    OpenG Capo4 Friend of Leo's
    Athens, GA
    This is what I do, with all types of glues. No need to rush / better safe than sorry.
    But... I guess if I were going for fastest build in the TDPRI challenge its good to know I can plane my blank after 90 minutes. :lol:
  11. henderson is go
    henderson is go Tele-Holic
    New York
    I wait a day and regardless of what glue I use (I've used titebond, fishglue, and hot hide glue)
  12. caferacer
    caferacer Tele-Afflicted
    phila pa
    to me the psychological advantage of knowing it was clamped all night
    out weighs any real advantage of leaving it clamped all night
  13. J Lacey
    J Lacey Tele-Holic
    North Georgia
    I appreciate the input concerning how long to wait before taking the clamps off a blank. We've been taking care of some remodeling over at my Dad's place on and off since last fall. His house was built in 1982 and was in need of some repairs. I removed the exterior door from his sunroom and replaced it with a more modern unit . The old door was a stain grade solid fur or spruce frame with a full glass in it. I'd already tried to talk our local junk man into coming to pick it up but he never showed.
    With my shop almost back up and running since I moved it from basement to out building I've been thinking about learning how to make some mdf templates and maybe route a body. Then I thought about that door frame and how I could glue it up for a couple of blanks to learn on. The wood looked decent and it was 1 3/4" thick. I removed the glass ,did some measuring, and began cutting. Only took a minute to realize the door wasn't solid but instead just veneered with spruce and everything inside was a puzzle of pieces and parts that were anything but pleasant to look at. Thought I'd go ahead and glue up the two blanks, build myself a body and neck template, and route 'em out anyway. I think all in all this will be a blessing rather than a disapointment. Be a good learning experience for me. Give me a chance to make templates and learn how to use 'em. Doesn't matter much at this point about the body wood.....you can build a tele from yard sticks, right?
    Thanks again for the responses.......
    Jeff
  14. Ronkirn
    Ronkirn Doctor of Teleocity
    Jacksonville, FL
    I clamp 'em up in the morning... fool around with something else till mid after noon.... cut 'em into blanks in the afternoon... a stack of 'em will be getting sanded for paint by the end of the next day,,
    Ron Kirn
