Gibsonette GA-8 inspired first build
Discussion in 'Shock Brother's DIY Amps' started by Mexitele Blues, Feb 13, 2020.
  1. Mexitele Blues
    Mexitele Blues Tele-Afflicted
    Westminster, CO
    Hello all, now that I have been reading and learning for a while I think it is time to get my hands dirty. In March '18 I found a 1960 Gibsonette on CL and fell in love with its thick, single ended antics.
    After servicing it and seeing how simple it was inside, the wheels started turning. So here is my plan for a modernized Gibsonette circuit. 1) Reign in the bass a touch and shore up what is left. 2) Allow for external speakers. 3) Switched NFB with a low pass setting for hairy highs and clean lows. (No idea if this will work or sound good!)
    I'd like to try out some other mods when finished, both proven and ill-advised, so this will be a mule of sorts, in a Princeton Reverb chassis with plenty of room and extra holes. This project's goal is to get a feel for the process and theory rather than turn out a polished amp on the first try.
    So there you have it, no finished tag board, no beautiful cabinet, only a schematic drawn by a noob who knows just enough to be dangerous. All tips, critiques, and comments are welcome!
  2. Splodgeness
    Splodgeness Tele-Meister
    Coventry, England
    There are people on here far better qualified than me who could comment but unless I'm reading your circuit diagram incorrectly, it looks like when you have no external speaker connected, you have a dead short to Ground across the Output Transformer..... (and also with a 4ohm external speaker, assuming that the top jack is incorrectly labelled as 8 ohm external)
    Mexitele Blues likes this.
  3. Mongo Park
    Mongo Park Tele-Holic
    Winnipeg
    I would separate the common cathode resistor/cap on the 6b6 power tubes. That way you can bias them separately.
    You could bias one hot one cool which would give you more harmonic distortion And get more depth from the parallel power tubes. Somewhere around 470 ohms is standard and something higher and lower would separate them.
    Cheers Ron.
  4. Squawker
    Squawker Tele-Meister
    Lommedalen, Norway
    I always thought the mismatched g1 resistors were an attempt at the same. On the original they're 0/470, in the suggested schematic they're 470/1K5.
    Also, you could keep the common cathode circuit and just not use matched valves (which is historically correct) :)
    Mexitele Blues and D'tar like this.
  5. Mexitele Blues
    Westminster, CO
    Thank you Splodgeness, I will give it a second look. The idea behind the speaker jacks is that if there is no internal speaker plugged in, the OT shorts to ground. The tips of both jacks are connected so that whatever secondary is feeding the external jack also feeds the internal. Then if 8 ohm loads are plugged into both jacks, the 4 ohm secondary carries the load in parallel.
    Hi Ron, I recall you were buying transformers for a similar build last year. Have you begun the build yet? Playing with the power tube balance is absolutely on the agenda after I get it going and hear the 'baseline'.
    My Gibsonette has its original Gibson branded RCA tubes, which indeed don't have any markings to suggest matching. I have a pair of mismatched JJ 6V6 which will most likely find their way into this amp.
    Any suggestions on the transformers? I see I have an email from Amplified Parts touting a 10% discount on Hammond for the next week so I should probably take advantage of that.
    muscmp likes this.
  6. Squawker
    Lommedalen, Norway
    My GA-8 clone thing has a Hammond 125DSE. It's quite a chunk of iron - Hammond are notoriously overengineered, but it's a general problem with Single Ended OTs that they need a big air-gapped core to handle the standing DC current.
    Edit: Ha - I see now that is what's on your schematic too :)
  7. Splodgeness
    Coventry, England
    My apologies ........ I guess I misunderstood the labelling on the diagram. I think what you are proposing then is that the intenal 8ohm speaker connects to the lower jack (labelled "internal"). Then a single external speaker would/could be plugged into the upper jack to effectively connect the speaker pair to the 4ohm transformer tap. What threw me was interpreting the upper jack as the one where a single external speaker could be plugged in with no internal speaker connected, which in this case wouldn't work........... :)
  8. Mexitele Blues
    Westminster, CO
    What did you use for your PT? The 290XXA is the Pro Junior replacement spec. I'm open to others if they will work better.
    Have you got a build thread on your GA-8?
    That is correct, no apology necessary. I wasn't sure how exactly to clearly label the intent on the schematic. That seemed the most practical application to me for an external jack as opposed to an impedance selector.
  9. Squawker
    Lommedalen, Norway
    Oh, now you're asking.... I can't remember, but I'll look this evening. Might even have been salvaged from something else. I don't have a build thread - there were some comments on the AX84 forum years ago when I was debugging some motorboating, but that's about all.
    Will get back to you later.
  10. Mongo Park
    Winnipeg
    Diverted likes this.
  11. Squawker
    Lommedalen, Norway
    I think the PT was bought from ELFA which is a Scandinavian version of RadioSpares or Farnell. Made by Swedish Tranformator-Teknik, model 56-003-09. 260-0-260, 3.15-0-3.15 (all heaters) and 0-5-6.3 winding (used for the lamps). Unsure about the current ratings.
    That 290XAX looks good, as does the 370DAX (or its 270xx equivalent).
    Or something like this https://www.tube-town.net/ttstore/toroidal-80va.html - that's in Germany, but something similar might be available closer to you.
    awasson likes this.
  12. Mongo Park
    Winnipeg
    Hammond 290xxa is plenty big enough. It would take some looking into but their is a way to pull both 6V6 and use one 6L6 but you need the transformers to run it. The 290xxa would do fine but the OP transformer would have to be able to cope with it as well.
    The build I did is 100ma, which runs this amp just fine.
    Cheers Ron.
  13. ArcticWhite
    ArcticWhite Tele-Afflicted
    Portland Oregon
    Why did you decide on a solid state rectifier?
  14. Squawker
    Lommedalen, Norway
    There is no musical advantage to a valve rectifier in a single ended amp. They don't sag like P-P so there's no natural compression/browning out from the power supply. Does provide a softer startup, but it's not a biggie.
    Solid state saves space and heater current, and can let you use a lower voltage rated power transformer.
  15. Mexitele Blues
    Westminster, CO
    Squawker hit it on the head. Space, simplicity, no need for a tube.
  16. ArcticWhite
    Portland Oregon
    Ha! I didn't know that.
    Why don't single ended amps sag?
  17. ArcticWhite
    Portland Oregon
  18. Mexitele Blues
    Westminster, CO
    Well the last few months have been interesting. This project was put on hold once my 2 school age kids had to finish out the year online. But since summer began the wheels have been turning.
    Shifting gears a bit, the plan for a mod mule in a PR chassis has given way to a finished amp in a 5f2 arrangement. The schematic remains largely the same with only minor changes in component values and fewer jacks.
    I have a layout completed that I'll post in a bit for comments and suggestions. In the meantime though, most of the parts are here. Just waiting on one more delivery from amplified parts with wire and solder et al.
    I'm working with the mill we do business with to get some nice clear Redwood 1x12 for the cabinet, since that is what the original Gibsonette was housed in.
    BigDaddy23 likes this.
  19. elpico
    elpico Tele-Afflicted
    Vancouver BC
    I'm seeing this for the first time. Don't know if you're still thinking about doing this:
    "3) Switched NFB with a low pass setting for hairy highs and clean lows. (No idea if this will work or sound good!)"
    But that's exactly what a presence control is (variable low pass on nfb) so yep, it works and it sounds good. Lots of examples out there to work from. There's also the rarer "resonance" control which does the opposite, and the truly funky hiwatt version which can do a little of both.
    D'tar and Mexitele Blues like this.
  20. Mexitele Blues
    Westminster, CO
    Here is the pared down schematic. I think it looks a little like a dog.
    And the layout.
    A couple of questions I can think of now -
    - Do I need to move the V1A grid stopper off the jack and onto the board? With input 2 removed it loses the triangulation of the second resistor. The coax shielding may provide some support.
    - Should the wire run to the 6V6 grid be coax?
    - I saw a recent post on referencing the heater ground to the 6V6 cathode by placing the artificial center tap resistors on the 6V6 socket. That would be a simple mod, is it worth it?
    Let me know if you see anything amiss.
