Gibson Wiring Question
Discussion in 'Just Pickups' started by Mind Flayer, Mar 5, 2021.
  1. Mind Flayer
    Mind Flayer Tele-Meister
    Chicagoland
    I have a faded SG and am replacing the stock pickups with Duncan 59s.
    While I'm at it, I figured I might modify the control setup. I miss having a master volume control, but I also would like to keep the ability to have individual volume control over the bridge and neck pickups. Also, I never, ever use the neck tone pot (I sometimes use the tone pot on the bridge).
    So, what I was thinking of was wiring it so that the four knobs function as follows: (1) bridge volume; (2) neck volume; (3) master volume; and (4) bridge tone.
    Is this possible? I don't really know what would happen if I had, say, the individual bridge volume at 4 and the individual neck volume at 7, and then started turning the master volume knob down, but I'm not so concerned about that. I'd be happy as long as the master volume worked like it normally does when the individual volume knobs are both at 10.
    I probably won't be doing this mod myself - I always seem to have problems soldering with gibson 3-way switches, so I'll probably take it to my tech, but just wanted to know if this is something is possible.
  2. Peegoo
    Peegoo Poster Extraordinaire
    Between the Raindrops
    Yes, it it possible.
    If your tech is unfamiliar with how to wire it up, have 'em take a look at a few Gretsch hollowbody wiring schemes; these incorporate a master volume in the circuit.
  3. Peegoo
    Here's an example from a Gretsch Jet:
    SAguitar, warrent and Telekarster like this.
  4. Telekarster
    Telekarster Tele-Afflicted
    Earth
    Awesome! This is why I love TDPRI! Ya'll are on top of it! I just rewired my 56 Goldtop RI back to 1956. Bought it used and someone had done some right goofy stuff in there, so I put it back right. Had to do a complete rewire, including pot replacement. Never worked with Gibby braided wire before, but once I got the hang of it, it wasn't too bad. She now has that 50's tone again.
  5. SixStringSlinger
    SixStringSlinger Friend of Leo's
    Space
    Yeah, you basically want a Gretsch-style set-up, though I'm curious as to how you'd achieve a tone control only on the bridge pickup. But I'm sure it's possible somehow.
  6. warrent
    warrent Friend of Leo's
    toronto
    Just move the tone control to the bridge volume pot instead of the master volume pot.
  7. Mind Flayer
    Chicagoland
    Thanks -- very helpful!
  8. SixStringSlinger
    Space
    So bridge pickup --> bridge volume --> tone control --> switch --> (everything else normal)?
  9. BorderRadio
    BorderRadio Doctor of Teleocity Silver Supporter
    Phoenix, AZ
    Also note that there are two ways to wire the neck and bridge volumes, on the center lug or the outer. If you want independent volumes, the pickup hot lead should be routed to the center lug.
  10. warrent
    toronto
    That should work.
    SixStringSlinger likes this.
