Gibson mini humbucker neck screws?
Discussion in 'Just Pickups' started by Chunkocaster, Dec 6, 2019.
  1. Chunkocaster
    In space with Ziggy
    I've been assembling a few partscasters with leftover parts I have accumulated and just installed a vintage Gibson or Epiphone mini humbucker in the neck position to fill the hole.
    I had a couple of screws from a cheap firebird pickup but they didn't fit so I MacGyvered it in there using the wrong screws with heat shrink over the threads and they managed to bite on the threads enough to adjust and stay put.
    The holes didn't appear to be threaded, how were these pickups originally installed? Nuts on the end of a threaded screw?
    rangercaster and Fretting out like this.
  2. Fretting out
    Fretting out Tele-Afflicted
    Land of Mary
    I think if they aren’t threaded then you are probably right about the having a nut of some sort
    I think gibson humbuckers are similar and mount to a bracket with spring and don’t have threads on the pickup itself I’m not sure though as I haven’t taken one apart in a long time
    Chunkocaster likes this.
  3. Chunkocaster
    In space with Ziggy
    Thanks, I have forgotten too. I tried soldering around the holes with screws inserted to create a faux nut but it just kept on breaking. The heat shrink is holding but I don't think it will last for many height adjustments. I think these usually have a plastic surround that may be threaded to take the screws depending on what it came out of. I bought it used years ago and cant remember what guitar it had supposedly been taken from.
  4. Dacious
    Dacious Poster Extraordinaire
    Godzone
    Gibson pickups all have a machine screw that goes through the ring and a spring into the tab. That holds the pickup at adjusted height
  5. fidopunk
    fidopunk Tele-Meister Silver Supporter
    Charleston, WV
  6. Chunkocaster
    In space with Ziggy
    Thanks, That looks like it would work well. For that price plus overseas shipping and tax I think i'll make do with the hack job for now.:)
    If I hadn't made a mess of the threads trying to solder I could have probably got away with a couple of small nuts and springs. I might have a go at making my own mount like in that link.
  7. JohnnyCrash
    JohnnyCrash Doctor of Teleocity Gold Supporter
    Fullerton, CA
    I made my own brackets. Bought a tap and die for 3-48 threads and used small aluminum flat bar sticks you can buy at a hardware store.
    A hacksaw can cut them to length. Drill a slightly smaller hole. Then use the tap to hand turn threads into the hole.
    Mine had soapbar style mounting rings though, and I needed to mount them to the pickguard of my SG:
    bender66, heffus, MickM and 1 other person like this.
  8. urbandefault
    urbandefault Tele-Meister
    Yukon OK
    The LP Deluxe mini has screws that go through the ring and the pickup ear, and a nut is soldered or brazed on. The screws then go into a threaded aluminum plate that is mounted in the pickup rout, same as for a soapbar P90.
    bender66 and Chunkocaster like this.
  9. Chunkocaster
    In space with Ziggy
    Nice looking SG, I think i'll just find some new threaded screws and use nuts and a couple of springs to mount it to the pickguard like a tele neck pickup.
    JohnnyCrash likes this.
  10. Chunkocaster
    In space with Ziggy
    Thanks, looks the same as the stew mac link. I considered making one but will look for screws and nuts to use with springs on the pickguard.
  11. Tommyd55
    Tommyd55 Tele-Meister
    Southern Louisiana
    Maybe superglue a couple of appropriate size nut onto the back side if the pickup legs.. Or solder them on..
    That StewMac kit looks like it would work nicely.
  12. telemnemonics
  13. bender66
    on my bike
    I just bought a HF tap & die kit to make some of these for a Filtertron set. Then Philadelphia Luthier had a sale so I just bought em. Once I recieved them I chuckled at how I should have made them myself. It was a push financially so I'm not out anything & I have a tap/die set.
    Telenomics has the right idea.
  14. telemnemonics
    6F1F77EC-1E4A-4B21-B4BD-D28C471395D8.jpeg I read this at work and found some clips in my cardware store stash but the wrong size.
    Here’s a Gibson full size with the tiny clip it came with, a Chinese mini with threaded tabs and a pat sticker mini with the same tabs as @Chunkocaster has.
    I’ve got the funny elevator rig from the old mini somewhere but it got cut off like they usually do.
  15. telemnemonics
    Nothing wrong with DIY but TV Jones makes the parts you need to mount your tron in Gibson rings or Fender guards. Not sure it fits a Gretsch tron but it should.
    The ring has outside Gibson and inside tron dimensions.
    Such a simple solution but took half a century to discover!
    Chunkocaster and bender66 like this.
  16. bender66
    on my bike
    It's for some Fidelitrons into a Gretsch bezel.
    They were pretty inexpensive at PLT so I wasn't so worried. I needed something else so wanting them came at a good time. I was just kind of excited to fab my own. There are plenty of other bits to make around my project piles.
  17. telemnemonics
    Yeah I like fabbing parts but was recently excited to see that TV Jones now makes it easy to drop trons in place of Gibson size HBs.
    Sadly the tabs can't be mounted on the dynasonics, but I think there are other options there too.
    I'm hoping the magnatron gets me toanz I love, basically a humbucking SC tone with extra power...maybe...
    If not I may go straight to the $20 import Firebird pups I've modded and like a lot, they just look funny in a full size HB bezel.
    Thought about putting a full size HB cover on one, image is important!
  18. telemnemonics
    So @Chunkocaster how do you like the sound of that junk drawer pickup?
    Those are maybe the best sounding HBs Gibson ever made IMO next to the old Firebirds with correct wire and turn count.
    If one must have a neck pickup anyhow...
    Durn guards all come with that durn hole that's gotta be plugged!
  19. Chunkocaster
    In space with Ziggy
    I haven't had the time to finish it yet. That maple neck you see in the pic is a spare strat neck I had lying around, I bought bushings to fit vintage tuners in the modern holes but then went and broke a tuner on another tele the other day as I was using a power peg winder for the first time so I used a tuner that was for this guitar as a replacement. I need to order a new tuner for it but have been busy working on a couple of other partscasters.
    This guitar is just getting all the leftover spares. I am looking forward to trying that pickup though. It might turn out to be a great guitar when done regardless of it being a random assortment of parts.
  20. schmee
    BTW: It's incredibly easy to solder a nut onto those mini's. A dab of flux, flow some solder on the pickup tang. Place the nut on there with a screw and heat until it flows! Remove screw. I use the nuts with the built in star washer on them.
    Volktar, heffus and Chunkocaster like this.
