mountainhick
Looking for help interpreting what's going on with the differences between these three iterations of screen voltage supplies.
The main things I am uncertain about:
1- I am not seeing how to calculate voltages for the screens in the second and third diagrams below. Looks like a two stage voltage divider, but if I calculate it that way, I don't come up with an appropriate voltage.
2- All three have a cap which look to me like AC blocking cap off the voltage supply to the screens.. Is this it's function? Does it also act in any way as a bypass?
3- I don't understand the relationship of plate and screen voltages in these circuits as they relate to gain and headroom. Any articles on this? or simple explanation?
4- Circuits 2 and 3 below had tremolo, which I removed from the schematics. They also had a 5 stage very steep cutoff CR network on the output to filter the LFO effect of the tremolo, I am not sure how this equates in terms of sizing a coupling cap. In series, the caps would total .001uf, but does that change with the resistors?
5- Any significant difference with the 411K vs 320K input impedances? The lower impedance seems to go with lower plate/screen voltages.
First diagram, "microphone" input on a Gibson GA-40:
Inputs 470K/ (3.3M+470K in parallel =411K) or .47 of the input voltage, 411K input impedance
220K plate and 1M screen resistors, (this I calculate as 47V at the screen) plus .05 bypass (blocking?) cap on screen,
1.5K Cathode resistor, and 20uf cap bypass
Second diagram, "instrument" input on a Gibson GA-40. This had a tremolo that connected to cathode and plate. This schematic has the tremolo and LFO filter removed.
both inputs same, upper input, 100K/320K, .76 of the voltage input. 320K impedance.
510K plate, 1M screen resistors, plus .25 bypass (blocking?) cap on screen
1.5K with 20uf cathode bypass
Case three: GA-20, also had same kind of tremolo removed from schematic.
inputs same 100K/320K, 0.76 of the voltage input, 320K input impedance.
A little bigger cathode resistor, 2.2K
