Getting the hang of STOMPING an Xotic X-W1
Discussion in 'The Stomp Box' started by riachuelo, Sep 27, 2021.
  1. riachuelo
    riachuelo Tele-Meister
    Mexico City
    Howdy. I bought an Xotic X-W1 several months ago and am really loving the sound of it. HOWEVER, I can’t seem to figure out the pressure you need to properly engage and disengage it. The button beneath the pedal out of the box was very, very firm, so I really have to stomp it hard to make it turn on and off. Is that normal? I’m still fairly new to using a wah and am surprised by how much force it needs. Is this in any way adjustable? By having to stomp so hard I’m a little more clumsy than I would like when using it. Thanks for any advice.
  2. kennl
    kennl Tele-Afflicted
    Moon Township, PA
    you should be able to adjust the height of the switch
    riachuelo likes this.
  3. Ringo
    Ringo Poster Extraordinaire
    Memphis TN
    It probably has rubber bumpers / stoppers like the Crybaby wahs, that the treadle hits, sometimes those can be cut down a bit to adjust how much pressure it takes to engage the switch, also the switch can usually be adjusted up or down a bit, but I find the rubber bumpers are the culprit most of the time.
  4. riachuelo
    Mexico City
    Yep, it has those. I am going to try adjusting the switch and see how it goes. Thanks.
  5. Hey_you
    Hey_you Tele-Afflicted
    Colorado USA
    I've reached down and used my finger more that once.
