Getting A Grip On Your Pick...
Discussion in 'Tab, Tips, Theory and Technique' started by AxRookie, Nov 8, 2019.
  1. AxRookie
    AxRookie Tele-Meister
    Las Vegas, Nevada
    I have been looking for something that would let me get a better grip on a pick that keeps it from moving around and needing to keep readjusting the pick position while at the same time hold the pick lightly and I finally found something that works very well.
    I had tried double-sided tape before but it ended up making my fingers sticky and the adhesive would get pretty slimy pretty quickly from the oils from my fingers and add to that the tape would pick up all kinds of debris so that was a bust, but it gave me an idea one night...
    Try 3M's VHB double-sided foam tape a try, it's 1mm thick and it grips in a different way than other tapes...
    This is 3M's description of their VHB tape...
    3M VHB Tape consists of a durable acrylic adhesive with viscoelastic properties. This provides an extraordinarily strong double-sided foam tape that adheres to a broad range of substrates with a Pressure-sensitive adhesive bond on contact to provide immediate handling strength.
    So I gave it a try and for me, it works great, since it's 1mm thick it makes the pick thicker at wherever you apply it which make the pick easier to hang on to using a little grip and just by feel alone you can tell which way the pick tip is facing, the adhesive doesn't get too sticky or slimy because it's viscoelastic, it doesn't pick up all kinds of debris because it is Pressure-sensitive, and it doesn't make me fingers sticky because it isn't really a sticky kind of adhesive with skin and if anything it cleans my fingers after using it and at the same time if you hang onto it for a few seconds it starts to grip your fingers in a good way that keeps the pick from moving around between your fingers!
    It's weird how good it works, I just put a strip of it on both sides of the pick and that's it...
    Here's a short video clip talking about how it works...
    Tim T, MrGibbly, Frontier9 and 5 others like this.
  2. bgmacaw
    bgmacaw Friend of Leo's
    Near Athens GA USA
    I don't use a pick that often but I wonder how this stuff would work lining the inside of a slide.
  3. stratoman1
    stratoman1 Friend of Leo's
    Virginia Beach, Va
    I use Dava picks. My fingertips are worn smooth, no fingerprints left on them so most picks just spin around. Dava picks are the only ones I've found that I can hold onto
    tah1962, Toadtele and PhatBoy like this.
  4. 985plowboy
    985plowboy Friend of Leo's
    South Louisiana
    I use Herco 50's or Brain 73's.
    They both have a lot of built in texture.
    I've tried putting little holes in smooth picks before, but I like the textured ones best.
  5. Flat6Driver
    Flat6Driver Friend of Leo's
    DC Burbs
    I use 1mm blue Tortex and scratch them up with my pocketknife for grip.
    I was at the acoustic guitar shop and they suggested some .80mm white "Cool" brand picks. They are nice. Have a little pad of blue grip on them.
  6. El Marin
    El Marin Tele-Afflicted
    Madrid, Spain, EU
    I do the same
  7. ronzhd
    ronzhd Tele-Holic Ad Free Member
    Spring, Texas
    +1 to Dava picks, and "Snarling Dog".
    Toadtele likes this.
  8. jman72
    jman72 Tele-Afflicted
    Central Florida
    I've used Dunlop Jazz IIIs for 25 years, and they have the new "max grip" version with built in gripper texture. They take some getting used to, though, since they are so grippy that you can't easily rotate them in your fingertips while you're playing even if you want to (and I realized that I move my pick around in my picking hand quite a bit when I play, so too grippy causes its own problems if your pick gets off-kilter during a song).
  9. Rustbucket
    Rustbucket Poster Extraordinaire
    Québec / Arizona
    I always felt I had a better grip holding the pick sideways such as this random photo I found:
    When I started, it allowed me to hold the pick with my thumb, index and middle finger for better grip. I’ve since freed up my middle finger for hybrid picking, but still hold my pick sideways.
  10. bcorig
    bcorig Friend of Leo's Silver Supporter
    In the 909
    I tried the double sided scotch tape and had the same problems you did.
    Quite by accident I obtained the three sided Zagar EZ play flat-picks and they solved the problems I was having (rotation, grip) and significantly improved my playing, both acoustic and electric.
    Telecaster88 and middy like this.
  11. ale.istotle
    ale.istotle Tele-Holic Silver Supporter
    Pennsylvania
    I love the Dunlop Max Grip's. Can get everything from 0.60's up to 1.5's. Jazz III's in different materials.
    Telecaster88 likes this.
  12. beninma
    beninma Friend of Leo's
    Earth
    I’ve found Tortex and Ultex to just be really slippery. I think different plastics might react to different player’s skin differently.
    Celluloid is a lot less slippery for me.
    Taylor’s “Thermex” is better.
    Blue Chips are very grippy but only work if you don’t lose them.
    Texture on the pick doesn’t seem to make much difference for me.
    For some reason I tend to dislike the tone of picks that are slippery too.
    bcorig likes this.
  13. Waitingfergodot
    Waitingfergodot TDPRI Member
    New Brunswick, Canada
    I happened across some picks made by a company called Cats Tongue. They have a bit of tack to them as they have an almost 'spikey' texture. They have a bit of a bite that keeps them from slipping around between my fingers.
    The attached image looks like a spoof but, I assure you, they are a real product and I quite like them.
    Sent from my SM-G950W using Tapatalk
  14. gkterry
    gkterry Tele-Holic Silver Supporter
    the Telecaster Forest
    V-Picks. Easy to hold and try thicker ones. I use the Big Fattie model which is 5.85mm thick. I find it takes very low pressure to hold a thick pick which helps my hand relax.
  15. Bortyeast
    Bortyeast Tele-Holic
    Televille
    Gorilla snot.
  16. ale.istotle
    Pennsylvania
    I'm buying these just for the packaging
    Waitingfergodot, Tim T and nojazzhere like this.
  17. blowtorch
    Wisco
  18. Dreadnut
    Dreadnut Friend of Leo's
    Grand Rapids, Michigan
    +1 on the Snarling Dog Brain Picks and the Cats Tongue picks. They just naturally grip your finger and thumb. I also have played Jazz III's for years, I'm glad they came out with grippy ones!
  19. joealso
    joealso Tele-Holic Silver Supporter
    Chester Co, PA
    I just reordered a pack of Dunlop picks and instead of the regular ones I usually use I tried their new max grip. It took me a little while to get used to the feel but I do like 'em.
  20. nojazzhere
    Foat Wuth, Texas
    I use Clayton brand picks, white, and usually 1.26 mm thickness. My biggest problem is I have some nerve damage in my thumb and index finger from my twenty years as a neon glass blower.The Claytons have a "texture" to them that helps my grip, although I often adjust a pick's position for playing effect. I'm gonna try those Cat's Tongue picks, they look interesting. (although I AM mildly allergic to cats.)
