General Telecaster Noise Question
Discussion in 'Telecaster Discussion Forum' started by Green Tele, Jul 30, 2021.
  1. LutherBurger
    LutherBurger Poster Extraordinaire
    Newyorkistan
    That kind of hum can be caused by a poorly shielded cable.
    thankyouguitar and PhredE like this.
  2. blue metalflake
    blue metalflake Doctor of Teleocity
    ireland
    Hums every which position equally
  3. Nick Fanis
    Athens-GREECE
    The American pro telecaster has RWRP pickups.
    It should be DEAD QUIET in the middle position so your guitar has a grounding problem.
    Fix it.
    Big-ez likes this.
  4. David Meiland
    David Meiland Tele-Meister Silver Supporter
    Friday Harbor, Washington
    Copper shielding made a lot of difference for me. The back of the pickguard has foil on it as well. 2020_04_05 (6).jpg Also did my Strat.
    Maguchi and PhredE like this.
  5. Green Tele
    Green Tele TDPRI Member
    Thanks for the pick! Looks really pro! Glad I saw this before my copper arrived for inspo.
  6. Maguchi
    Maguchi Tele-Afflicted
    Lalaland
    Yeah, it shouldn't be that noisy. I have 2 Am. Pro Tele 1s and and you can barely hear a little noise when it is silent. I'm guessing there might be some electronic issues. After your "authorized repair shop" traces and fixes the problem under warranty, you can always shield the control cavities for even quieter operation. Good luck!
    LutherBurger and PhredE like this.
  7. Maguchi
    Lalaland
    Nice work! Looks much better than mine.
  8. Dano-caster
    Dano-caster Tele-Holic
    Snore'n desert
    Have you guys got 60 Hz hum or 50 Hz hum? Is there a difference? Just asking...
    Boreas likes this.
  9. Sparky6string
    Sparky6string Tele-Meister
    I served under a General Telecaster.
  10. Boreas
    Boreas Poster Extraordinaire
    Adirondack Coast, NY
    It would need to be grounded somehow to be effective. There seems to be a glob of solder or something near the control plate, but I see no wires.
  11. Boreas
    About 10 Hz!! :lol:
    In the US it is usually it is going to be 60 Hz.
  12. Dano-caster
    Snore'n desert
    I know that. The OP is in Australia init...
    Boreas likes this.
  13. Maguchi
    Lalaland
    Don't know for sure, but I would guess that 50 cycle hum and 60 cycle hum are pretty much the same thing. The hum from alternating current in electric wiring, appliances and florescent lighting etc.
    Boreas likes this.
  14. Siamese
    Siamese Tele-Meister
    Muskegon, MI
    oops
  15. Boreas
    O I C. It would be 50 Hz there.
  16. thankyouguitar
    thankyouguitar Tele-Meister
    Dearborn, MI
    Though the cable isn't the issue in my case, were it the cable I imagine it would hum at all volume settings.
    Might I propose the volume pot as the culprit?
  17. Dano-caster
    Snore'n desert
    Yeah if your good at soldering and desoldering you could bypass the volume or switch it with the tone control if they're the same values.While you are there look over the rest of the soldier joints real good...
  18. LutherBurger
    Newyorkistan
    Not necessarily. I've only experienced that problem once, with a cheap cable that came with a cheap guitar. I threw the cable away, and since then I've never had it with that guitar, nor any other.
    I don't fully understand the phenomenon, but it has something to do with the guitar's output impedance, which increases dramatically when you turn down the volume from 10.
  19. Arfage
    Arfage Tele-Meister
    Alameda Ca
    Well that's a trip. Usually the "humbucking in the middle position" doesn't seem to work, but more noise? That's odd. Maybe check if they hooked it up backwards. The metal plate on the hot could cause noise. My favorite strat bridge pickup is a DiMarzio Fast Track I bought because my friend had the tele version and I loved it. I had to rout out my strat because the pickup is taller (.906") but the bridge hole on a tele is typically pretty deep. If you do that, do some checking first. It's a great Fender sound, loud, no hum.
    Big-ez likes this.
  20. schmee
    The 3 way doesn't noise cancel like a Strat in 2 and 4.
    I find very often that Tele's are noisy. Does the noise improve when you touch the strings or hardware?
    Shield the guitar and it will be fine.
