gb Custom Shop
I've seen some pretty expensive fret beveling files around, and honestly the prices are a bit outrageous. Anyone with a half decent table saw can make one in minutes. Here's mine
I use my hand as a stop at the nut end, so I don't smash the file accidentally into the headstock. Did that on my first neck though lol. A few minutes of filing and that's done.
I will eventually tape up the fretboard for when I'm leveling, crowning, and polishing. Before I get there I want to do a couple things.
The very bottom corner of the fret end, I want to file that now, before applying tape. Here's a closer shot of what I'm talking about. The left side had the corner relieved, whilst the right side is untouched. I'm only doing the very bottom here, I'll do the rest after crowning.
I'll follow that up with some 320 attached to a piece of leather, attached to a piece of wood. I go in circular motions, clockwise down the neck, counter clockwise up the neck, focusing on the fret ends. This will further smooth those fret ends, but also start to break the fretboard edge.
I'll further break the fretboard edge with thin strips of sandpaper, working in a lateral motion, not up and down! I focus toward the fret ends, and then bring the centre together.
I personally dislike when rolled fretboard edges take on a scalloped look. That's why I do it this way. Although you wouldn't want to go overboard here
However once that's done, I'll give it a smooth over with 800 grit real quick up and down the fret ends, with the same block and and piece of leather. Feeling pretty good so far!
I'll get the fretboard taped up now. It's kind of nice leveling and crowning while the neck is still flat. Just comes at the risk of having to do it all over again once the neck is under string tension. I'll take my chances
