gb Custom Shop
I've learned plenty from this forum the last couple years, and was always impressed and appreciative of everyone's build threads. So, I figured I should post my own! I am currently working on a thinline tele, and seems like a good time of year to share what I've been up to.
Let's start with the neck. My wood choices are torrefied maple, and a katalox fretboard (first time using katalox) The maple was from a 2-1/4" thick piece that I was able to resaw a slice and drum sand down to 3/4". I'm using a stewmac low profile truss rod with headstock access.
I use the router table with a fence to route this out. Since this truss rod has a full length rounded bottom, I decided to try using a 1/4" ball nose bit. Then since this truss rod is wider at the end, I used a 3/8" round nose bit, which accommodated that portion of the rod, but also became my truss rod access hole. I route till the truss rod is a hair shy of the surface. I got a super snug fit which I'm very happy about.
Moving along to the fretboard. First let me say, katalox is no joke to work with. The densest wood I've ever worked with. Anyways, I start by cutting fret slots at the table saw. Double stick tape fretboard to my template, and then I use the stewmac blade in my crosscut sled.
Frets are cut and fretboard is ready for glue up. But first, I route my neck flush with the template and mark tuner holes. Take the template off then line up the fretboard and clamp dry. Once clamped I drill a hole thru the fret slot, so I can use a couple brads for alignment. Since the katalox is an oilier wood, I hit the underside with acetone right before glue up.
Here you can see I'm just using titebond. I got my brads in place, and a caul with holes for where the brads go (so I can take the brads out once clamped)
I clamp from one end to the other, and I let this one sit a couple nights. First glue up complete!
